Burkulater
OK I found a lot of good info on here about turn signal, hazard, and brake wiring but I'm left with one question.
i have a 68 that Im pretty sure has a 66 wiring harness, the one wire from the brake light switch is connected to a red and black that goes in the column which is correct from what Ive read and brake and turn signal lights currently work. My question is that the other wire is hooked up to the yellow wire at the steering column connector Is this right? Its a heavier gauge wire that I think should go to the column for the horn..... does this circuit do both the horn and the brake lights? I dont see any other wires that always have 12v handy under the dash
thanks
thanks
