X2...master cylinder internally bypassing fluid assuming no external leaks. It's a sealed system, so if the pedal sinks, the fluid has to be going somewhere, and in most cases, it's back up into the master cylinder reservoir. As stated above, it's not uncommon to have the master cylinder fail (or begin to fail) shortly after bleeding the brakes, especially if you go long intervals between bleeding the brakes. Under normal operation, the pistons can only move so far in the bore of the MC before they hydraulically lock, but when you bleed, you're stroking the pistons the full length of the bore, which may have corrosion, pitting, etc on the bore wall and can damage the seals.
I'd replace the MC, doing a plugged-port bench bleed first, as this should tell you whether the new MC is good or not, versus recirculation bleeding which does not provide any definitive feedback. Once the MC is fully bleed with plugged ports, it should hydraulically lock with minimal piston stroke (~1/8") and shouldn't sink over time with steady force. Assuming that is the case, I'd install it, hook up the rear brake circuit and bleed that circuit only with the port to the front brakes still plugged. If the lines are already full, I'll crack the fittings at the MC and bleed out the air there first and then flush the system if you need/want new fluid everywhere. Next, the the same with the front brake circuit and then you should be done. I typically flush my brake system on my older rigs every 2 years just to keep the fluid fresh and prevent corrosion.
