I've been working to get my rig stopping better. 35" tires, 351w.
I recently replaced the front drums with discs from WildHorses. That install was fine, but the brakes still weren't great. So I have replaced the master Cylinder with a Wilwood unit from Wildhorses, had literally no brakes after that, so I figured maybe the booster itself was worn out. I bought a new unit from WH for that as well, with everything bolted up, my pedal travel is fine, and the brakes do bottom out but it just doesn't feel to me like I am getting much assist. I got the 1 1/8" bore wilwood cylinder. Also, the front discs were a complete kit, including a new prop valve. Everthing is bled, and everything seems to be installed fine, it just feels I have to stand on it a bit to much to get it to stop.
Any ideas? The brake lines all look fine, no pinches, no crimps, and tons of fluid when bleeding. I am going to check the vacuum, but it definitely feels strong with my thumb on the end. It is thick walled 3/8" hose going directly to the back of the carb. Any ideas would be greatly apprecated.
