Kyle.malone
Getting ready to bleed the brakes and have to finish hooking up the lines. Am I getting these lines in the correct positions? The larger reservoir (line on left of master cylinder) is connected to the front of the prop valve (very front). The hole directly behind it goes to the front extended brake line on the frame. What size fitting is this to connect to the extended brake line from the axle to the frame?
The smaller reservoir (line on the right of the master cylinder) is connected to the top rear (behind the brake warning light wire) and the frame brake line going to the rear is conected to the very rear.
Do I have this correct?
If it makes any difference, I got the power brake set up from Toms as well as the Prop valve for Disc brakes.
