Brake Prop valve.. Help
Kyle.malone
Norman, OK
Getting ready to bleed the brakes and have to finish hooking up the lines. Am I getting these lines in the correct positions? The larger reservoir (line on left of master cylinder) is connected to the front of the prop valve (very front). The hole directly behind it goes to the front extended brake line on the frame. What size fitting is this to connect to the extended brake line from the axle to the frame?
The smaller reservoir (line on the right of the master cylinder) is connected to the top rear (behind the brake warning light wire) and the frame brake line going to the rear is conected to the very rear.
Do I have this correct?
If it makes any difference, I got the power brake set up from Toms as well as the Prop valve for Disc brakes.
Kyle.malone
Kyle.malone
Norman, OK
I have found out that the connections at the master cylinder are correct. And so is the hookup for the rear at the prop valve.
The connection at the prop valve for the front is suppose to be connected in the hole closer to the brake warning switch. and the very front port goes to the front axle line.
My only problem now is I have ot find a fitting to go from a 3/16" to a 5/16" fitting. I already checked at Napa and they don't have anything. Looked at lowes and they too don't carry the sizes I need. Any other ideas?
71broncman
Maysville, Ky
I feel your pain, man. I spent a lot of time at Napa and Car Quest digging through the fitting bins when I did mine. One other source might be a hydraulic hose repair shop, although, I think I found some of the fittings at Napa, some at Car Quest, and 1 at the local hose repair shop. (Whistler Bearing) Good luck, .... Mark
turbotim2
____________
Do you mean a 3/8" to a 7/16"? There are no 3/16" or 5/16" fittings in the brake lines. Are you just looking for the flare nuts? I noticed Advance had some in a package on the wall when I was there recently. I would think most any parts store would carry the fittings.
NGABronco
Always Learning
N. GA now South Carolina
Most of the parts places have short tubes (6") with fittings, I had to buy 2 different ones to get the fittings and then make up a new line???%)%)
