Bronco 289 cam help.
Daveyd
Orange County
I looked pretty hard and couldn’t find a post on the cam I’m looking at. Here on Craigslist there’s an a312 can for sale for 70 bucks new. Is that a decent choice for a stock 3speed 289 with just duals? And should I buy new springs any time I replace the cam? Thanks for any help. I have a new timing light, recurring my dizzy, water pump, timing chain and all gaskets so I was kinda thinking what the heck, why not. And while I’m asking, does match porting heads help that much on these old 289s? I’m really just looking for it to be a daily, and well behaving on the back highways at about 60, driving 2 hours each way on the weekends. Thanks in advance for your help
Tiko433
I know just enough to be dangerous
Bolivia, North Carolina
I can't answer if it's the right cam for you regarding performance. Your block is going to need a flat tappet cam. Although it is a flat tappet cam I'm not a fan of reusing a flat tappet cam. From what I understand once broken in the lifters have to stay matched with there lobe. So even if the guy has the lifters for it you have to trust he kept them matched. And yes some cams will require new springs.
bronconut73
He says the cam is new.
Check Summit or Jegs. You can get a cam and lifters pretty darn cheap. Don't bother with the Craigs list cam,even if it is new.
Summit and Jegs have a tech line to help you get the right cam, lifters and springs.
Port matching is great but sbf heads actually mostly suffer from pour exhaust ports. You may get more performance out of a set of headers than port matching, but hell do both.
B RON CO
Statesville, NC
Hi, the Ford Motorsport cam you found is a high Rpm performance cam, more suited to bracket racing then 4 wheeling. If you want to change the cam I would go with an RV cam for low RPM torque, from idle to 4,000 or 5,000 RPM. As mentioned, get a cam and lifter set, engine assembly lube, and motor oil with extra zinc. You may not have to replace the valve springs for a stock ride, but if you want to rev your motor think about what could be wrong with 40 year old springs. Good luck
WheelHorse
You'd be better off installing an aluminum intake a 4bbl carb if you want to add a little pep to your 289 for a low cost.
289 2bbl to 4bbl gains
Unless it's just been rebuilt, I'd leave it alone and just drive it.
IF you can't leave well enough alone, Edel 2122 cam. It works with stock seat pressures. I run it with a set of mildly cleaned up E7's and stock spring pressures with no valve float on my 302.
I should add all my seat pressures were checked and corrected by a machine shop, on my E7's, before installing them with a more aggressive cam.
broncnaz
Cams are a good way to get the power where you need it. As was said you need to have the correct one for your setup. Usually the performer cams mentioned are good for most everyone. Intake and carb mods are fine but they only move the power band upwards you see very little to no gains on the lowend where broncos run most of the time. Plus don't expect to see the numbers they state in the article. If your current setup is well tuned the power difference will be pretty small. A lot of times those tests are done with a ill tuned or detuned engine then they swap parts and tune for max gains so you see big numbers and get excited. While there are gains to be had they are not always that big.
It can all kind of snowball swapping a can may need you better power where you can use it. Fords need help on the exhaust side more than the intake so exhaust mods tend to be worth more than intake mods. Intake mods are usually done for better tuneability. When the parts are all matched up you'll see the most gains. And for the most part it helps to do all the mods so each part has the best chance to reach is full power making capability. That doesn't mean all the mods have to be done but they do help each other.
Port matching wont hurt but you may not see any gains from it except on a dyno.
Timstrk
cam choice
You don't have to stick with a 289/302 cam, either. A 351W cam will work in the small block. It just changes the firing order. Research the numbers to find the power band you want for the application you're shooting for. Daily driver, torque, high end rpm, etc. Then you can get the cam.
