I converted my 72 Bronco (302-C4) to EFI about 10 years ago using the complete EFI from an 89 Crown Vic. The engine itself is an early 80 stock 302 with a mild truck cam and headers. The engine has been running great for the last 15 years with a few minor issues along the way (fuel pump failed, alternator, etc) but overall very reliable. I had 2 pumps - low pressure pump at tank and high pressure pump near engine but switched to sigle high pressure pump at tank in the course of trying to solve the current mystery.
Approx 3 weeks ago, my Bronco started hesitating when throttle was applied under load and would gradually get worse until it would not rev at all and would eventually die and not restart. I have a fuel pressure gauge in my dash that showed good pressure but based on previous issues, I tried replacing the low pressure pump which had been an issue a few years before. That didn't make a difference and I borrowed a diagnostic fuel pressure gauge to confirm mt dash gauge and fuel pressure is consistent 34 at idle and approx 44 when vacuum is removed from the FPR. I also put in new plugs for good measure and checked vacuum (17 at idle).
After a few days, I drove it again today and it ran great for about 5 mins- I drove around the block and got on some open road where I could test throttle response. All was working great but I had to come home when it started raining (no top on Bronco at the moment). After it stopped raining, I took it out again and all semed good for the first mile and then it started hesitating when throttle was applied. I think I am getting a very lean condition based on the sputter and backfire. Fuel pressure is still showing consistent around 34. By the time I got back home, I could barely get it to go up my driveway. It would idle fine and pull OK with very light throttle but anything more than light throttle caused it to stumble.
I've also checked KOEO codes and nothing so far. I'll check again later today but haven't seen any flashes of the CEL which I think would accompany a code.
Eng temp is ateady at approx 185 on these short trips (gauge is wired direct to sender- notreading from Eng computer)
I think I have a fuel problem but fuel pressure seems to be good and consistent.
I welcom any ideas to check- I'm stumped. Thanks
