Bronco 67
RVZIO
New Smyrna Beach
Picked up a new ignition bezel. Car had none. Trying to put the key tumbler back in. Lined up the notch and the tumbler but it won't snap in and stay.
Thoughts
RVZIO
B RON CO
Statesville, NC
Hi there is a procedure that I vaguely remember involving the key in and turned to ACC (I think) and a paper clip in the little hole.
To remove and install the key tumbler.
Good luck
.94 OR
Willamette Valley, OR
Right out of my 1967 Ford Bronco service manual.
I despise Apple's photo orientation!
There is also a secondary issue with the crappy reproduction parts we have now, that take a little poetic license with the factory original specifications.
Does not sound like you're at that point yet, but the new ones are often off by just enough to create a bind when you do finally get the cylinder back in. It usually shows up when you turn it to the START position and the key won't come back under the spring pressure and you have to do it yourself. Big PITA really.
Of course, if your dash has been painted (or especially powder coated) and is thicker than original, this puts more of a bind on it.
The bezel is at least one culprit, but the spring pressure on the switch itself is the other. They work together to make you pull your hair out.
Maybe that's why the PO left the bezel off in the first place? Maybe there was a new switch and the new bezel just didn't fought them too.
Good luck.
BajaBronco
I'm not sure who makes it, but DirtDonk probably is on the right track. The repro bezel that most sell is garbage. I've had one machined to fit and work, but it's not something I'd recommend money wise. Original is best.
The people with powder coated dashes and/or those nice little stainless dash protector thingies suffer the most. That extra thickness involved may, or may not have given the original parts trouble, but they sure mess with the new stuff.
A friend tried grinding the slots anchor in the bezel a little deeper to let the pressure relax a bit, but the bezel broke with just the slightest pressure from the Dremel. Not sure if a different bit, or a different speed would have helped cut the pot metal (or whatever it's made of?) any better, but it didn't willingly get ground.
We've experimented with removing the little aluminum key slot cover, cutting the springs on the switch, rotating the springs to a different clock position, trying to open up the center bore of the bezel a tiny bit, but none of that was a reliable fix.
Each "fix" worked with some parts. But some parts just played nice together better than others.
