bdrake1 said:
There is no good answer here.
"MOTOR, DRIVETRAIN,TRANSMISSION"????
Well you need lower gears for the 35's
Mud requires power/torque and speed= Stronger motor
Stronger motor puts more stress on the drivetrain= stronger axles,u joints......
You will also want to be taller than the mud hole your driving through= lift, bigger tires,lower gears
traction is a big plus=lockers
It goes on and on....for everything you change, you must change something else. It all depends on how you beat on the rig. For every 20 guys that reply, you will get 20 different answers.
Take your pick, build one up and break the others. Its never ending.
If you have to pic one do the gears.
