BroncoBub Build
LUBr LuvR
If a clean chassis is a happy chassis, yours must be ecstatic - nice work!
BroncoBub
BroncoBub
Since I'm keeping the stock 2 tanks system I was playing with line routing. This is a mockup. Would there be anything wrong with this configuration? Than going along frame to fuel pump and brakes.
chuckyb
Hey Bub, I also have the two tank set up and used the top of the frame rail for routing a vent line from the aux tank. The only drawback that I can see would be if you had to work on any of the lines later, would you be able to access them ok when the body is back on.
BroncoBub
BroncoBub
I thought about that also, I am installing a 1" body lift and if I had to work on the lines I should have enough room to get a allen wrench on the screw heads.
Thanks Chuckyb for responding,
Bub
BroncoBub
BroncoBub
Installed the rest of the brake lines and test fitted the proportioning valve. Need to take the bracket off that holds the valve on and paint it so it won't rust.
BroncoBub
BroncoBub
Steering Box Rebuild
Rebuilt the steering box and restored it back to new condition..
BroncoBub
BroncoBub
Started the resto of the drive shafts. Painted the shaft with steel color and the yokes with a cast iron grey color. Need to finish up some more details.
BroncoBub
BroncoBub
Drive shafts completed
Just need to assemble them and install new universal joints. On to the next phase...Engine and trans next. Just to let you guys know....my wife calls me anal too!
sprdv1
REBEL
nothing wrong with being particular.. lol :D
BroncoBub
BroncoBub
Drive shafts in the books!
Drive shafts completed! On to rebuilding the C4
BroncoBub
BroncoBub
C4 Housing
Prepped the C4 for painting. Degreased it cleaned it degreased it cleaned it! Painted. The transmission is getting rebuilt as of this posting.
BroncoBub
BroncoBub
After bead blasting the exhaust manifolds, cleaning process ready for paint.
I used the exhaust paint by VHT and followed the off engine directions for curing the paint. I must say they came out great!
Off the Vehicle
Paint must be completely dry before curing
Heat to 250°F (121°C) for 30 minutes
Cool for 30 minutes
Heat to 400°F (204°C) for 30 minutes
Cool for 30 minutes
Heat to 650°F (343°C ) for 30 minutes
Pictures are after bead blasting, than during curing and final product.
BroncoBub
BroncoBub
Prepping the engine for assembly and paint. Need a few more parts (alternator brackets and water pump pulley). Making sure all pulleys align correctly etc..More to come later.
BroncoBub
BroncoBub
C4 rebuild complete. Have to touch up some paint that I forgot to do. Painted the T/C cross member and side mounts.
