BroncoBub Build
BroncoBub
BroncoBub
OK changed the springs around without damaging anything. Thanks again, Paul!
Well, not exactly disastrous maybe. But at least now you don't have to make up a great story about the Bigfoot sighting in your neighborhood forcing you to throw them on in reverse so you could join the mob quickly and hang your burning torches from the shackles better with the extra support while allowing you to travel in reverse safely and securely with the best torch-view possible, every time someone points out that "hey buddy, did you know your springs are on backwards?" and stuff like that.;D:eek:;)
Actually I can't take credit for it. Was talking to another member and they asked about it. Good eyes here all the way around!
BroncoBub
BroncoBub
Before and after pictures of the rear.
BroncoBub
BroncoBub
New 3.50 rear gear set came in today.
BroncoBub
BroncoBub
Pumpkin
After cleaning up the inside of the rear carrier (pumpkin) would this be a indication that the outside may have the same color as the inside?
Yeller
Rogers County Oklahoma
It was not unusual for the inside of the carrier to be painted, I've taken plenty apart that were painted, however if they were wet inside I've seen them rusted where they were a solid iridescent color so its hard to say.
BroncoBub
BroncoBub
Ok I got you!
svastano
Pulaski, PA
The red paint is most likely a product called Glyptal. it was used a lot in cast. All of my old John Deere's had the stuff painted on the inside of the cases. An old timer told me that some of the castings were so porous that the oil would seep out thru them and that is why they painted it with this stuff:
https://www.eastwood.com/glyptal-red-enamel.html?SRCCODE=PLA00020&msclkid=c24f0e3f870e146e5c226e62afde2508
BroncoBub
BroncoBub
BroncoBub
BroncoBub
Got the 9" all buttoned up. New gears, ring & pinion
seals. Next up new axle seals and install axles and rear brake drums.
BroncoBub
BroncoBub
Brake drums installed.
BroncoBub
BroncoBub
Was able to finish up on the rear drum brakes today and currently installing hard brake lines.
BroncoBub
BroncoBub
More progress, started installing Dana 44, shocks and control arms.
BroncoBub
BroncoBub
Since I screwed up the left steering knuckle on the Ford F150 I bought it off of I went with the gm setup. Test fitted everything and so far so good.
I just have to grind some of the knuckle down so the caliper can have back and forth movement. Now I'll just have to sell off the ford conversion parts I bought.
Edit: Went back to the all Ford disc setup thanks to forum member Joe31969. He had the left knuckle I was needing and sent it to me..Thanks very much Joe!!!
BroncoBub
BroncoBub
Completed the rebuild of the Dana 20.
BroncoBub
BroncoBub
More progress except I have the wrong caliper on the passenger side.(as of this post I corrected it) Installed the passenger side disc brake conversion with all ford parts. Just for grins I installed the rim and hub cap. Drivers side tomorrow.
Bub
BroncoBub
BroncoBub
Have a rolling chassis again.
