Trans, motor, ecu, gauges, suspension, fan, rad, steering pump, gas tank, brake lines, etc all arrived. Stilling waiting on the front and rear axles and brakes to really get started. Desert classic mustangs in Scottsdale sent me some pics of the body - will be ready next week. They did some mods to the firewall to fit the gen3 Coyote and built a custom shelf for the ecu to live behind the dash.
Have More parts than time at the moment.
I know how that goes! How was your experience with the shop that built the body? We have been looking for local recommendations for someone. Thanks
The manufacturer should have data on actual tire diameter which is usually not in synch with the actual tire size.Center of axle to floor around 17inchs right? Assuming 35s and little a squish in the sidewall.
BFGs K02 = 34.53 inflated diameter. Thanks.The manufacturer should have data on actual tire diameter which is usually not in synch with the actual tire size.
For a 2 1/2 suspension lift those measurements would be 9 1/2 in front and 8 1/2 in the back.
Absolutely to all of the above. You can’t know…
Even Duff doesn’t know because they build that kit for Broncos in general. Not for your specific bronco with your specific engine transmission and transfer case and lift height combination. Correct installation is up to the installer only, and really only when everything is in place and sitting at ride height.
The 5° of adjustment is just for fine-tuning after you get it as close as you can.
The 1° to 3° down bubble is primarily for leaf spring setups. A four-link can actually get away with 0° because in theory there is just minimal angle change when in use. But I’d prefer to see at least one degree built in.
