C4 - build it myself or pay?
jeffncs
Raleigh, NC
My resume - very mechanically inclined, rebuild manual transmissions (several), built multiple car / jeeps / broncos.
I just pulled the 3rd crap c4 from my wife’s bronco and don’t want to do this again any time soon…. I also have 2 more broncos to build which will all be c4 trucks…
Do I pay the man to build this 1 and the next 2? Or do I take it on myself and roll the dice?
Steer me down the right path……
fordguy
Isn’t there a video series out on the bronco C4. I would like to find a good source for a kit, we have a local who is a good builder. Viperwolf posted a list of parts I believe.
jeffncs
jeffncs
Raleigh, NC
I’ve heard of bad shoe on YouTube…. Supposedly he’s “the man”’for C4s.
jamesroney
Fremont, CA
C4 is a super easy transmission to rebuild, and has the ability to be easily pressure tested after re-assembly to ensure it is done properly.
The removal of the clutch pack pistons requires a spring compressor, but a press and some fixtures can do the trick.
The biggest problem with a C4 rebuild is that the "enthusiast" always seems to want to do something stupid and "improve" the valving, or shift points, or add a "shift kit." It can work perfectly fine for 50 years, and someone will try to make it better. DON'T.
If you have a known good C4, with known history, that worked fine (until it didn't) then a stock rebuild kit is all you need. Just remember that it will leak ATF on the bench from the minute you open it, until you finish it. When you re-assemble it, you can't be too clean.
Do it yourself. Especially since you have 3 to do. Handful of special tools, but by the time you get through all three of them they will have paid for themselves.
I had a college class on automatics decades ago. The transmission that was used was a C4.
The tricky bits will be getting the piston seals in without tearing them. But the right tool makes it easy. The bushings can be tricky as well. But it comes apart and goes together pretty easy. The parts get put together and you are not dealing with a bunch of small parts, but a few big chunks.
stock Bronco valve bodies have a factory "shift kit" already in them. Don't go adding more shift kit, you will just screw it up. And many rebuilders will automaticly add a shift kit because they think it makes the transmission last longer, not knowing they are screwing up the factory one already in it. Instead of firming up shifts, they make it bang gears. And it is nearly impossible to undo putting one in.
Torkman66
New Braunfels, Tx
I have the same background as you. Lots of mechanical background, many manual transmission rebuilds, but never an auto. I bought the Bad Shoe video and did it myself. Easier to do than rebuilding a T-5 for sure. Actually kind of fun. I purchased a couple specialty tools for under $40 and had zero issues. At one point even emailed the Bad Shoes author and asked a question. He got right back to me. His video walks through every single step from disassembly to final adjustments. Well worth the cost. Go for it! And yes, tranny works perfect.
Bajabrewer
I did my C4 with the Bad Shoe videos & would do another. If you decide to do it make sure your work area is set up to handle trans fluid - big flat tray or couple storage box lids with a lip to hold fluid. This helps with both disassembly and putting it all back together - keeping it clean & organized is also a priority.
Good luck & let us know how it goes
I'm with the C4 is easier than a manual transmission. Few more specialty tools, but a good one to do.
fordguy
Roney, do you have a source for good rebuild kit’s?
Kbpony
I did mine back in 1997, still shifts great and it sat for 5-6 years. As others have said, don’t add a shift kit, keep it clean, and have an area that you can keep track of everything coming apart in order to put it all back. Just buy a complete kit, either a new torque converter or drain and flush the old one. You really want to clean all the old sludge and fines out.
jamesroney
Fremont, CA
I buy everything from TransStar. They have a local branch, and keep everything in stock. But I usually end up buying hard parts at the same time.
But I have to admit that SummitRacing has extraordinary customer service, and stocks the ATP kit and TCI stuff.
fordguy
They make a fair size grilling tray to go under your cooker, would make a good work surface, has a lip around the edge. I use one when I change oil on my vehicles.
79INA69
I second TransStar or Transparts Warehouse Inc. They have good quality rebuild kits with Raybestos clutches or Borg Warner. You can get Alto and other higher end materials, but for a quality stock rebuild these 2 locations will have everything, and worth the price.
jeffncs
jeffncs
Raleigh, NC
Thanks for sources. I’ll look there tonight.
Related questions….
What should I look for in a kit for it to be “complete” kit? I’m trying to get everything to avoid further downtime once I start building it.
Also - how do I flush the radiator and cooling lines to clear out the old junk / debris from the burnt up trans?
They make spray can cooler cleaners
Lubegard 19001-UNV Kooler Kleen Transmission Cooler Flush​
Although just replacing oil to air coolers is generally best as they can hold debris depending on design. The in radiator should flush out just fine, it is a real simple tube in tube. Not the little creavases of a stacked plate..
fordguy
Good thread now does somebody have a c4 to donate to me so I can get the video and attempt a rebuild? “Asking for a friend “ lol
jeffncs
jeffncs
Raleigh, NC
I can’t donate but I do have a couple for sale currently. Make the trip to Raleigh!
