c4 kickdown cable setup?
SpareParts
BC Bronco's makes a kit for EFI throttle cable and C4 kickdown cable. I installed them on a customers Bronco this month. Both cables could have been a little longer to make routing easier and cleaner looking, they do seem to work.
The C4 cable isn't in the pic yet, I guess I didn't get a finished pic of it.
golfobx
Suffolk, Va
I want to be clear on what you were saying.
When you go full throttle, should the kickdown lever on the actual transmission go towards the front or towards the rear of the vehicle to engage.
SpareParts
It depends on the position of the kick down on the transmission. One the BC Broncos one, the cable comes in from the top towards the rear. It bolts on to the servo with a little tab from one of the corner bolts. In its case, it pulls the lever up and back. With this kit, it does come with a different lever. The factory one pushed down and back with the lockdown rod. The lever is spring loaded and will only go one way and should return to its normal position on its own.
Rhoward
Newbie
C4 kickdown
Hey Spare parts.
I know this post is old but I’m researching the BC kickdown cable. I have installed but have not been able to figure out how to mount bracket to transmission. Do you have any pics? The ones that came with it are terrible. Thanks
gr8scott
This is how my Lokar mounts. Maybe it's similar?
SpareParts
Hey Spare parts.
I don’t…. I’ve done so many customer installs since then I would have to dig back in my files to even figure out what customers rig I was working on back then.
sprdv1
REBEL
what's that labor rate again? :D
