FoMoCoBronCo
- Feb 20, 2023
- 73
Hi, I was hoping that this forum might have some suggestions to solve my clearance issue. I’m running an Edelbrock 600 CFM carb on an edelbrock performer intake. I inherited the carb from the PO, and I swapped in the performer during the rebuild because it sat lower than what it replaced by at least an inch- giving my the hood clearance to run a standard 2” air cleaner.
However, while connecting my Demotor (Lokar knock off) kickdown cable, I found that parts of the cable are rubbing on my valve cover (as pictured, circled in red).
I need some guidance deciding on where to start. I don’t want to give up the valve covers, and I’m worried that additional spacers between the carb and the intake to move the car up will cause hood clearance issues.
I know that my 600 CFM Edelbrock is overkill for my stock 302; are there perhaps smaller carburetors that won’t stick out as far? Or can anyone else make any suggestions or recommendations.
Thank you in advance!
