c4 question---servos
cody72sport
im confused and hoping someone can shed some light on what servos are what. i know that the bronco servo is an h servo. i have read several places that the c servo is the best. the transmission i am rebuilding has an A servo. how does the A servo compare, how does this letter system work(A,C,H etc)????
Viperwolf1
electron whisperer
The letter is just the code that Ford picked for the servos. The servo is actually a double sided piston with each side a different diameter. One side applies force to tighten the intermediate band and the other side applies force to release it. The bigger the diameter is the more force multiplication there is. The "H" servo has the 2nd largest apply area (square inches) and the largest release area of any Ford C4 servo. The "A" servo has the next smaller apply area and the same release area. "A" is good for a mild V8.
More here: http://mmb.maverick.to/showthread.php?t=29643
cody72sport
cody72sport
so a 'c' servo would be overkill? where could i get a good deal on an 'h' servo?
Viperwolf1
electron whisperer
You probably don't need the "C" servo. There are aftermarket servos that have the same apply/release size as the "H" but I'd get one from a wrecking yard or here: http://mmerlinn.com/
I've bought some C4 parts from him before.
broncnaz
A lot of trucks came with the H servo. The R servo is supposed to be good as well but some claim the servo really doesnt matter much. But most people like to run the H's or R's.
