C4 Question
67halfcab
Michigan
Can I remove the bottom cover without running into problems?
I want to paint the bottom cover and want to make sure I'm not going to run into problems by removing it as it was already rebuilt by the PO and it is in great shape.
TIA
md_lucky_13
Idaho
Absolutely!
That is what is commenly known as a transmission filter service, or a "pan drop and filter" service.
Just be ready for about 6 pints of ATF fluid to come rushing out at you. If you are going to drop it, go ahead and replace the transmission filter while you are there. Very easy to do. Then just fill it back up with fluid, and start. Thats it. Make sure you replace the gasket, and re-torque the bolts after a few hundred miles.
67halfcab
67halfcab
Michigan
md_lucky_13 said:
Absolutely!
Thanks, That is what I was hoping for. I just installed it so I'll only see about 1/2 pint of fluid as it's empty now, so I figured I might as well paint the pan now and changing the filter is a good idea too.
HotWheels
Twilight Zone
dont forget that pesky little spring and piston that always falls out when u do this...make sure you put it back in.
