You're C4 will hold up just fine as long as you take care during the rebuild process. Use quality parts and find someone who takes some pride in their work, if your not going to do it yourself. You can throw in some things like a six pinion planetary, and hardened input shaft to eliminate some of the weak points, but that is optional. Another thing is to make sure it has a good cooler. I'm running a plate and fin cooler located in front of the radiator and it works great. My current C4 is awesome. I don't think I could be happier with it. It has held up fine to my stroker motor.
Take care
