iwlbcnu
- Nov 1, 2001
- 3,342
Sorry, long story no matter how I try.....
Had a C4 rebuilt, new convertor, new radiator, was running Mercon V and the intermediate band broke, maybe 2000 miles, but at least 5 years. Being lazy, I had a second rebuilt at another shop, new convertor, and blew out lines. Swapped it in using Redline D4 ATF and was having shifting issues right away. Builder was to far away so I have been trouble shooting myself. He had me swap valve bodies from first trans. And that fixed the issue........... so, me wanting to end up with two good transmissions, tore into the valve body and found the 1-2 and 2-3 valves stuck. Cleaned them, got them working and reswapped.
All was fine for roughly 100 miles and then shift issues again. So I reswapped. All was fine for roughtly 100 miles and then it wouldn't shift to third unless really high rpm, found out passing gear was stuck in. So I spent alot of time and really went through the second valve body and made sure it was clean and working freely. Did another swap, and the first valve body was working good except for a 2-3 flare up. Well that lasted roughly 100 miles and now 1-2 valve is stuck again.
So.....each time I have just drained the fluid, strained it and reused since relatively new, but am thinking it has to be the cause. The second valve body never had an issue until in this fluid. Each time it takes very little to unstick the valves, seem to be working smoothly, but then stick after use.
The builder says I can switch back to plain old Mercon V so that is my next step, just looking for input. Really hate throwing $200 worth of Redline away.
