Good read. And in some ways, the opposite of what I said.
While the first paragraph mentions lower rpm range, it doesn’t say specifically what the aspect change is. But the rest of the article states pretty clearly that the wider the lobe separation, the smoother the idle, higher engine vacuum, and other things.
A smoother idle and higher vacuum and probably lower emissions are very likely why you see modern EFI engines running 114° instead of 108. And thumper and lumpity rumpity cams having narrower angles.
