Changing gears from 3.50
NashBronco
Flowood, MS
Can someone give me an overview of what all is involved in changing gears?
Currently I have a 67, original 289 and 3 on the tree. 99.9% pavement driving. Have a 1” body lift and running 235x75x15 tires. I do plan on upgrading the motor at some point but will likely go with the blueprint 306. I understand that 351’s are popular but that’s not the route I want to go. I also have a new AX15 that I plan to install sometime soon. I have a Dana30 front end and....I assume Ford 9 rear?
When I upgrade the engine and transmission I figure I will want to change the gears. So question is. To what? 4.11? And what all has to be changed out?
Jdgephar
In order to pick gears, need to know what size tires you intend to use.
Changing the gears usually is done by a shop, unless you have the know how and tools to properly set them. The dana 30 up front will likely need a new carrier for the gear as there is a different carrier for 4.11 versus 3.50. The Ford 9 in the back has a crush sleeve that will be needed. New bearings and seals are good to put in while you're in there.
jdeignan
+1 on new bearings and seals. WH sells a sweet kit for $100ish. If you’re going through the process of changing gears, you might as well.
Not sure what you have for tools and skills, but I wouldn’t consider myself a master mechanic and I just did redid mine in the garage. Torque wrenches (foot and inch lbs), backlash measuring tool, youtube, and a solid vice are mandatory. Brought the new bearings to a shop to get them pressed for a few bucks.
spap
Why do you think you need to change the gears on a street rig with stock size tires.
If you went with bigger power it would just turn the 3.50 gears easier
Now if you going bigger tires that’s when you look towards changing the gears
While all Early Broncos came with a Ford 9" rear end, it's still a good idea to verify visually. I've seen some strange things installed over the years!
But most likely (like 97 percent) you still have a 9" rear end.
First, don't change the gearing until you get all this put together and see how you like the 3.50's that we assume (for now) are in there already.
Your tires are barely 28.5" tall on the vehicle, right? If so that puts your freeway rpm near 2500 rpm at only 65mph with 4.11 gearing.
This is not a deal breaker, and better than most EB's achieve. But your new strong running engine can probably pull the 3.50's at that speed very easily.
With 3.50's you'd be at 2100-2200 at the same 65mph.
If the engine is strong down low and not just a race engine, this could be a sweet spot for your vehicle.
So to know for sure, measure the rear tires on the ground, from the center of the hub to the ground. This is your rolling radius. Double that and that's your rolling diameter. This is the actual height of the tire on the vehicle and what everything is based on.
I was only guessing at 28.5 so it would be nice to know for sure.
No matter what though. I say save your money and your brain power until after the Bronco is built and you're driving it out on the road.
Then choose your gear ratio based on your actual driving experience. You might just find the existing gears work perfectly with your smallish tires.
NashBronco
NashBronco
Flowood, MS
This is all great info. I was under the impression that i pretty much had to change gear ratios with the bigger engine and transmission. good to know that I can wait and see what its like. I have all the tools to do the job but have not done it before. Ill wait and see what its like and then decided if a gear change is needed. I do plan on sticking with the same tires that I currently have.
The stock sized tires really change things. I think the best answer here is to leave them alone until the end. The 3.50 gears are very likely the correct ratio for those.
Timmy390
Conway, AR
The rear is easy.....Well not easy but with a press and an understanding of how it works and how to adjust it you can do one in no time. Don't even mess with the crush sleeve. Get a solid spacer and make life easy.
The front (I've done a D44) is harder and you will need setup bearings. You have a choice to either get a new carrier (due to the split) or run what's known as "thick" gears. They allow you to run the gears without a new carrier. You don't need a case spreader but the instructions call for one. The front is time consuming. I bet I had my carrier in and out 20 plus times before getting everything right.
Tim
76YETI
KC METRO
I have a strong 5.0 HO out of a 1995 F-150 (carbed) tied to a C4 transmission, ford 9" with 3.50 factory gears. I'm running 33's on 15x10 wheels. It is basically a street rig....It has plenty of power and cruises nicely. This site is awesome, but it also makes you want to constantly upgrade everything! When reading posts remember your type of driving!
it depends what you do with the transmission if overdrive is in your future you will have to recalculate your gearing at that time.
... I was under the impression that i pretty much had to change gear ratios with the bigger engine and transmission.
Nope, it's almost never about the engine and transmission taken by themselves. But it's ALWAYS about the tire size.
