NotAMechanic406
- Jul 9, 2020
- 2
1976 Bronco
302
Hey there! This is the first time I have posted on a forum and it's not even my vehicle! This might be a long story. My boss learned I have some tools and half a brain and some experience as every car/truck I have ever owned I bought used and half broken down anyway. As I have other work to do on the clock for actual paying customers I don't want to spend any more time on this than I need to. If it's not too complicated, sure I will do it. I'm on the clock anyway. But if it's WAY beyond my tools and capability then I'll tell him to pay a real mechanic.
That all being said, let me catch you up...
Boss man drove his Bronco to work from his cabin about 90 miles away. He got half way here and it was overheating and losing oil pressure. At that point he just called a friend, got a ride to his truck and trailer and loaded it up to come here.
My guess was that we should start by replacing the thermostat and the oil pressure was likely due to the overheating. He said that he had a new radiator and thermostat put in last summer and that maybe something was wrong. But as long as I am looking at it, let's install a new oil pump.
Sure. Why not.
I started it up, got it off the trailer and pulled it in. I noticed a strange chirping noise coming from below around the bell housing. I did a bit of research and decided that as long as I was pulling the pan and replacing the pump I would replace the rear main seal as that was a possible solution.
Things went well. Pan gasket was all but gone, got it loose, pulled the pump then the pan. Cleaned up the pan surround, installed new gasket, replaced the main seal, put the pump in the pan, moved it back into place, installed the pump, then the pan. Changed oil filter then filled it back up. Drained coolant, went to replace the thermostat and noticed it the current one was in backwards. I researched placement just to make sure and yep. Backwards. Installed new one anyway, replaced gasket and filled her up. Fired it back up and the chirping remained. I went under again and looked. Glad I did as I noticed the washer on the drain plug was broken and leaking.
I would appreciate ANY insight or help. Thanks!
Here is a link to a short video on google drive:
https://drive.google.com/file/d/1HmmNefKt4IRdMKbes1xI-Z6T0h3OcV1k/view?usp=sharing
302
Sure. Why not.
