itsabronco
I had a post awhile back about my clutch shuddering very bad on taking off. Came to conclusion it was a warped flywheel, brand new out of the box. I will never install another flywheel without having it turned first, or at least checked.
Ok, that problem solved. New issue is, I lost all of my pedal as if it has a hydraulic clutch on it and there was a leak and it ran out of fluid. Each press of the pedal, I had less and less pedal, till eventually, I had to shut it off, put it in gear, and restart it, shifting like an 18 wheeler to get her home off of the trail.
I checked all the linkage, its all intact, there is no slippage of clutch, still very strong. WTF??? The part that is suspect to me is the clutch fork or throw out bearing fork, what ever you call it, is cracked or something.
Will the fork come out of the bell housing without removing trans??????? Please someone tell me
"YES IT WILL". and be serious about it ! It does seem as if it is flexing and not depressing the pressure plate all the way. Have not had time to dig farther yet.. What do you think ? ? ? ?
