Iron Knight
- Jan 5, 2022
- 13
Hi there, guys... and greetings from Chile. Please, let me tell you my sad, boring story...
I have a 1966 Bronco, which had a 289 V-8 engine in it, and I wanted to make an engine upgrade, 'cause I wanted my Early Bronco to pull a little more, in order to tow my boat, since this "boat", a Sea Ray SRV-255 Flybridge, it's a little too big for the Bronco (perhaps I should get myself a Freightliner to pull it?
). I bought a 5.8L, casting number begins with F4TE, which makes me think that it's a 1994 (maybe 1995) truck engine, according to the info I've gotten so far. I wasn't sure what kind of a truck the engine was in when they pulled it out, but my strong belief is that it belonged to a F-350. The engine also came with a gearbox, a ZF S5-47, which I got rid of (sold) right away, 'cause it was 2WD, not 4WD (not able to install my Dana 20 behind it, it would've been the first 2WD Bronco), and I didn't want to go for the "budget" solution... anyway, besides of the typical engine rebuilding (pistons, piston rings, bearings, gaskets and so on, so forth), I wanted to get rid of the "hoses & wires salad" EFI system, and made it carbureted; installed an Edelbrock Torker II, carburetor adapter and a Rochester Quadrajet (yeah, it's GM, not Ford, I know) I found among my stuff, and the engine runs nice and smooth, which is good. I also put a Proform HEI distributor on it, wires, plugs, etc., very good, smooth running, no smoke (not visible, at least)...
I payed little attention to the clutch, though; a quick check, pilot bearing was OK, pressure plate was OK, disc was OK, alignment was OK... it was time to bolt the good old 3-speed tranny (Ford 3.03), along with the good old Dana 20, to the 5.8L engine... it was like this:
- The 289 had a 157-tooth flywheel... the 5.8L engine has a 164-tooth flywheel. Time to get another clutch bellhousing... I got it, good fit, no problem.
- The clutch fork of the 289 was of the bail wire style... the new bellhousing couldn't fit the bail wire style clutch fork. Time to get another clutch fork (the tab style one)... I got it, along with a new throwout bearing, no problem.
Engine, tranny and transfer case are on frame... yeah!!! Way to go!!! Hoses, wires, everything hooked up... start the engine... feels like WOW!!! But, when I tried to put it in gear, the gearbox made a diarrhoea-like sound (or maybe it was my belly, since I was so anxious and nervous)... reverse gears are not meshing, and syncronizers are not syncronizing...
The clutch won't disengage, no matter how precise the adjustment is... on my way to remove the whole thing and see what's going on...
Now, refreshing my memory a little bit, I realized that the engine has a LuK 07-117 clutch kit, which is the one that comes with those ZF S5-47 transmissions, equipped with the so-called "concentric slave", hydraulic throwout bearing. Clutch disc is a little bigger than the stock 11 inch, 11 9/16 inch, if I'm not mistaken. The spline count is the same (10), the input shaft outer diameter is the same, 1 1/16 inch. It could be that the disc hub got stuck in the input shaft, but I don't think so, for the shaft splines and disc hub splines were in good shape, no rust, clean and well lubricated. It could also be the pilot bearing, but I don't think so either, 'cause there are no noises. Because I didn't have an alignment tool at the time, I aligned the clutch disc with the very same Ford 3.03 tranny input shaft, since the tranny was out of the vehicle and dismantled back then (rebuild time), and the shaft was turning on its own axis very softly, very smoothly, I really don't believe there was any problem with the pilot bearing, even though it is highly recommended to replace it every time you service the clutch.
Is it possible that the pressure plate is too tight on the flywheel, perhaps too much torque on pressure plate fasteners? Does this kind of clutch work with normal (standard) throwout bearing?
Please, help me... I'll be reading your comments... thank you so much...
