OldIron1912
- Dec 2, 2016
- 5
Hi All,
Hoping to fix an issue that came up this weekend with my '70. It just started "popping" at about 1/4 of the travel of the clutch pedal. With someone else pressing the pedal while I was under, it seems to be coming from the clutch fork area. The clutch fork seems loose and if I put slight pressure (one finger) up it stops. I also removed the rubber gasket and I can see that there is a slight shift in the clutch fork as if its popping into place when the noise occurs. Other than being annoying, it doesn't look like it causes any other issues. No clicking while in gear, shifting is still smooth, etc.. Any ideas what I've got going on here or what I can do to take up some of the slop in the the clutch fork?
Thanks in advance!
Thanks in advance!
