Dark Knight
Huge difference, i really like them.
I forgot to add that Coco has a Centech harness. Power is ran through the aftermarket headlamp switch, no headlight relay mod. I wonder if they'll be even brighter if I put them on straight power from the battery with a relay?
Very nice Dusty! Are those the same style of lights that Heus33 has for sale?
Just curious about fitment... I looks as if they're a slightly smaller diameter than the H4's and protrude out from the trim ring quite a bit. Any chance of getting a profile close-up to see how much they stick out, or is it my eyes playing tricks? Overall, great looking with a MAJOR light improvement. Well done.
Also, are those led running lights/turn signals on the divider bar?
how did you do all your other led conversions for the side markers and tail lights? do it yourself or a vendor? thanks
great write up also, those look incredible. i'm very curious to see how these would compare to the JW SPEAKER model. i was going to get those until i saw this. these are much much much cheaper so if anyone has experience please share. thanks
I'm not Dusty (or Heus) but I'll give the quick answer and let them fill in any details.
No, they're not the same thing. Dusty's are off-the-shelf LED's (light emitting diodes) and Tom's are custom-made HID's (high-intensity discharge) lights like you would see on most higher end optioned cars these days.
Both put out some serious light. Don't know the lumens, or even lumens-per-watt of each one, but they both look pretty good. Especially where the all-important beam-pattern is concerned. Which is an area that way too many lights fall way too short in.
I think his HID's are 35 watt output (55 is optional, but not generally for street use) and Dusty's LED's should be about 30 watt equivalent.
Both pretty bitchin' options.
