I did a search and found a lot of good info, and tried those suggestions, but it still won't start. I recently installed a 4Wheeljunky wiring harness, and have not been able to start the truck since. The engine will crank over, but no fire coning from the ignition coil, going to the dist. (secondary high voltage side) With the key on the coil (+) posistive terminal has battery voltage.(primary low voltage side) I've tried 3 different known-good coils and 3 different known-good coil wires (coil to dist.) I've run a jumper wire from battery (+) pos. to coil (+) and still no help.I have a MSD Pro Billet dist. with MSD Blaster coil, that all worked fine before the wiring harness install. All suggestions will be appreciated.
