CRAZY AWD idea...
brewchief
If running GM trans(and possibly motor) I might look at what GM used in the cyclone and typhoon trucks that they built for a short time, I think the same case may have ended up in the Olds bravada as well. Output might be wrong side but a custom front axle could be built.
If you build an AWD bronco pay close attention to the front driveline angles, it's going to have to be perfect or it's going to vibrate.
No way I would swap in a BB chevy motor, if I had to run a GM motor in an early bronco it would be a very healthy LS motor, probably supercharged.
Ranchtruck
True, the AWD case out of an Astro/Safari van would be a good match to the 700r4.
I don't see a 700r4 lasting long behind a big block unless you drive like a wimp. Which kind of defeats the point of having a big block? I also don't see the point of a big block in a bronco, there's not that much weight to get moving off the line where you'd need the torque of a bb and a turbo on a small block will give you all the horsepower you could ever want.
