- Joined
- Feb 2, 2006
- Messages
- 114
I'm in the process of installing a new blueprint engine in my '72. I am currently working on getting the clutch linkage back together and have ran into a problem that I'm hoping you guys that actually know what you are doing can help me with. The newer engine block does not have a mounting hole for the bracket which means you need to get one of these to attach this. The problem I've ran into is the holes don't match up as seen on my attached picture. Noting is tightened in the picture which shows there is some wiggle room, but even once you use that up I still can't get a bolt into the hole. If the bar was flat without the cylinder channel I would just drill the hole into a more oval shape and call it a day. Any ideas? Thanks in advance you all.
