Cutch Equalizer Bracket - Advice?
NorCalBronco
I'm in the process of installing a new blueprint engine in my '72. I am currently working on getting the clutch linkage back together and have ran into a problem that I'm hoping you guys that actually know what you are doing can help me with. The newer engine block does not have a mounting hole for the bracket which means you need to get one of these to attach this. The problem I've ran into is the holes don't match up as seen on my attached picture. Noting is tightened in the picture which shows there is some wiggle room, but even once you use that up I still can't get a bolt into the hole. If the bar was flat without the cylinder channel I would just drill the hole into a more oval shape and call it a day. Any ideas? Thanks in advance you all.
i3adme
n00b
Not a answer to your question, however I appreciate you posting the bracket. I recently rebuilt my clutch and noticed my '86 302 didn't have the mounting hole as well. Had no clue this bracket existed.
Jdgephar
I ended up grinding my 351 block, and then drilled and tapped a hole for the bolt.
lilthom
Ditto on doing a bit of grinding. I just did this recently. The instructions even pointed out it may be necessary.
NorCalBronco
NorCalBronco
Thanks guys. I was aware I had to do a little bit of grinding to get the bracket to lay back flat but didn’t anticipate needing to grind the whole face on the bolt hole down 1/8”+. This will be interesting
