Dana 30 and 35s, and will they fit
OldieTwoShoes
Raleigh, NC
Basically I am planning on doing some upgrades and one thing that I'm having conflicting views on is if my stock d30 will stand up to 35s. I don't do much offroading anymore and my bronco is my daily driver which sees mostly around town driving with some highway miles thrown in the mix. Secondly, I am planning on getting a 3.5" suspension lift and I'm wondering if they will fit or not. The other option is to go with 33s but I think they might look too small.
this is how my bronco is currently with stock suspension and 32s (also I have 4.11 gears and won't be changing them) side pic
70HalfCab
Mandeville, LA
For a daily driver I would think you would be better off with 33s. I think 33s and a 3.5 lift looks just about perfect. This is mine with that setup. By the way it has 4.11 and a D30 too.
I would recomend 33's as well. Brakes work better, kingpins and wheel bearings last longer. generally better overall.
Then just do a 2½" lift which will help with the driveline angles and they will last longer.
Note, with proper flares/trimming 33's will work with no lift at all. fills out the wheel wells very nicely. I liked the way mine was with no lift and 33's, but I hated dragging everywhere offroad. Then I aquired most of the parts for 3½" of lift so I put it on. For a daily drive I would do a little less just to keep getting in and out easier. My seat cushion is taking a beating after the lift. All that sliding in and out on the edge.
justinoshea
Gilbert, AZ
The D30 should be fine for what you wan to do with it. 35s will fit fine since you have cut fenders. your moving the body up 3.5" and the 35" tires will only be 1.5" taller than 32s from the axle center line.
DanWheeler
Kirkland, WA
i did 35s on my D30 w/ 3" body lift for a long time and even wheeled it pretty hard and had no problems. Just stay off the skinny pedal.
ep67bro
Bronco Junky
Easton, MD
Stick with 33s! Look at mine it has 33s and a 3.5" lift . I drive it hard on and off road I have a dana 30 front and had no issues. You can fitt the 35s but you are going to rub like cray if you go offroad. I still rub a little with 33s when I wheel hard. I think that 33s and 3.5" lift are real classic look that you cant go wrong with.
