- Nov 8, 2008
- 111
Afternoon,
Regarding my Dana 44 pinion install. I have two baffles, one is flat and one is stamped. The one that stamped the previous installer had on the outside of the outer bearing. There was no baffle on the inside behind the inner bearing shims when I disassembled it. If I have this correct, the stamped baffle should go inside the housing just behind the shims where it lays against the inside of the housing. The flat baffle (or maybe it’s a second slinger) should go on the outside of the outer bearing. I hope I have explained in the way that makes sense. I also have a pictures attached if that helps. Thanks for the help. Have a great weekend.
