Darting under hard braking
nboost
Edmond, OK
Let me start with my rig. It's a 1966 halfcab. I put power disc brakes on it and everything was fine. After I put my 2 1/2 inch lift it seems to dart either direction when I am under hard braking. I have replaced all the bushings, new tie rods, track bar bushings, etc. Everything under the vehicle is new. It didn't do this until I lifted it. Just wondering if there is something else I should check. The only thing I haven't done is put on a drop bar bracket or adjustable track bar. Would these help with this issue?
blubuckaroo
Grease Monkey
Ridgefield WA
Our '77 had a 2.5" lift for years with just a hint of bump steer. Nothing we couldn't live with. Then I swapped the auto tranny out for a manual shift. Every time I upshifted, and the nose of the car dipped, it would bump steer. Not a particular hard bump steer, but now I had one hand on the shifter and only one on the wheel. It made handling kind of squirrely. The remedy was a dropped pitman arm.
Are you 100% certain you installed the C-bushings correctly? Surprising how easy it is to get them backwards. Depending on the offset, you might be able to tell by looking at them closely, or eyeballing the pinion angle to see which way it's pointing.
That said, it's not unheard of to get bumpsteer with 2.5" lifts. Most people consider them low enough to not need the dropped pitman arm and dropped trackbar bracket. However, you are still changing the angles of the steering links in a negative way, and doing that can cause what you're experiencing.
In the end, if that's what it is, don't just to one or the other as far as the drops go. For your year and style of steering you must do BOTH a dropped pitman arm and trackbar drop bracket. This keeps the angles as parallel as possible.
Another thing that can at least contribute is the steering box. Because by lifting it you're usually pulling it slightly off-center from it's normal straight ahead position, it can act more sensitive to input from the road, and less sensitive to your input from the steering wheel.
That's where an adjustable draglink comes in handy for 2.5" lifts. A dropped pitman arm "might" fix this length issue, but because of variations in each vehicle, it might not always be precisely back to stock, so the adjustable draglink can fine tune that.
Good luck.
N
nboost
Edmond, OK
Leave mine to be the odd ball. I also had to add shims to the rear due to vibration when taking off.......This is the best pic I have right now.
Clean rig ya got there!
Hard to tell for sure by the dark pic, but initially your steering linkage angles don't look horrible. Certainly steeper than stock, but not the worst we've seen around here.
Is the darting you're experiencing consistent? Does it go one way when accelerating and then the other when braking? Or can it go either way, like things are just overly "loose" up front?
If the latter, then yes it can be that you have too low a caster reading. That can be from the way the truck was made, and you just got away with it barely before the lift, or, as mentioned the C-bushings could be in backwards which reduces good caster too much.
The other "loose" feel comes from the now-steeper angles on the steering and suspension links after the lift kit.
As well as that previously mentioned off-center position of the steering box adding to the loose feel. A definite possibility among all the others.
As well, there could be some new issues with the brakes that weren't there before, and just coincidentally cropped up after the lift. Things like loose wheel bearings, loose ball joints, loose brakes or sticking brakes, or brakes that are just on the ragged edge of binding up by interference with the steering knuckle.
To that end, when you peek down over the top of the tire on top of the brake caliper, can you see daylight/gappage between the caliper and knuckle still? If not, time for more grinding.
Most of the stuff I gather is new? So ball-joints not likely an issue, nor bearings unless they're not adjusted perfectly or are coming loose. Which is very possible on these things.
None of that is as likely as just having slightly too steep an angle on the draglink and trackbar, but all are things that can possibly effect your road manners during braking.
Good luck.
N
nboost
Edmond, OK
Thanks Paul. Everything up front is new. I checked, double checked when I installed the C-bushings so I know they are installed correct. I put in 7 degree bushings. I only noticed this after the lift kit. It darts only under hard braking, but it also seems to do this when it hit big bumps in the road. I guess the next step is to install a dropped pitman arm and the track bar bracket. Thanks for the help everybody now I at least know which direction to go.
Scoop
Bronco Old Fart
Cuchara, CO
We need a better pic to see how your track bar and drag link line up. Even if the bars look parallel you need to see if lines drawn between the pivot points of each are parallel. We need to be able to see the attachment points of both. What you describe sure sounds like bump steer.
Timmy390
Conway, AR
What's your toe set at? Think I set my toe at 1/4 inch in. It's been 3 years and can't remember. It might be 3/8ths in. How much air pressure are you running.....
On my 2.5SL I run it all......Drop pitman, drop T bar bracket, adjustable T bar, adjustable drag link and 7 degree C bushings. Everything is new including the steering box. Drives like a dream at any speed.....
My rig like 28psi in the front or it will wander and hunt groves in the road. Different tires like different pressures on different rigs. 30 is ok but above that and it just doesn't drive well. Lower pressure doesn't see to bother it.
Oh and I removed the steering stabilizer. It drive so good without it I never put it back on.
Tim
Came back to this late, to mention toe-in too, but Timmy's beat me to it luckily.
Was looking at the pics though, and wondering about something. While your angles are close to parallel, they're not exact (at least visually by the pics) and I wondered how that could be with a virtually stock tie rod setup. Then I saw the pic of the tie-rod end at the driver's knuckle and wondered why it's sticking so far down and looks like a funny angle?
Is it tight? Is it in the hole enough? I see the stud sticking out an appropriate amount through the nut, but that's a big gap both beneath the nut and beneath the knuckle/arm.
I think you'll benefit from the drops, but even before then, why not perform "the test" to see what's going on up front?
You might have done it already, but this is where you have the vehicle weight on the ground and a helper turns the steering wheel back and forth enough to make the tires turn slightly left and right of center. Don't need to turn all the way each way yet. Just enough to put some force into the linkage while you watch.
You're looking for anything that's even the tiniest bit loose. Everything should move something else without any free-play.
While they're continually turning the wheel, watch very closely every little rod end or component (like trackbar) to see if it's moving without moving something else.
Loose steering linkages add up to sloppy steering pretty quick. Your stuff is new, but if for some reason it's not working properly, now's the time to find out.
