Daves 71 NH Build
Slednut10
Guru? That's funny!
Good to see progress, Dave. Where are you getting your grit?
dave67fd
dave67fd
Thanks guys.
Art,
Black Diamond at Tractor Supply, $8 for a 50 lb bag. Used 100lbs to do the axle, backing plates and one "C" cap.%)
Jason,
Thanks. Let us know when you start, would love to check it out.
Slednut10
Guru? That's funny!
Art,
That's where I picked up mine too. Had to bring back 3 bags because they were wet inside and I did not catch it until I unloaded them from the truck. They like to store stuff outside.
dave67fd
dave67fd
Ya Art, there were only three left on the shelf when I went, maybe the three you brought back;D. No, they were pretty dry. The blaster I have used quite a bit of media and alot of air. Almost makes me want to look for a larger compressor.
Slednut10
Guru? That's funny!
Nah, you would have known if it was wet-clumps like kitty litter:p
My 80 gal 2 stage Puma is rated at 20 SCFM-it keeps up fine while blasting with my 'little' PK Lindsay unit but generally doesn't shut off until I stop or run out of grit.
dave67fd
dave67fd
Thats the ticket. Mines only half that:cry:
Slednut10
Guru? That's funny!
Which nozzle are you running? If you can drop a nozzle size it will help with the air consumption and help a bit with grit use too.
dave67fd
dave67fd
Not sure. The one that came installed with it but I did get 2 or 3 others with it as well. It made short work with the one I had but yes I have read up on them and it's all in the nozzle on consumption on both.
I also want to change out the ball valve for the grit feed from a wing knob to a lever. Pain to adjust.
Thanks for the input Art.
dave67fd
dave67fd
Found some time to blast and paint a few more items.
Cleaned up and detailed my 25 yr old premiums and started on the 44.
dave67fd
dave67fd
Tore down the 44. Axle u-joints and ball joints are out.
Then got her blasted.
Made some room in the garage to tuck the tub in the corner.
migs
Lookin good!
I'm jealous that your corners are big enough to just tuck a tub out of the way... show off!;D
fatboy
Glad to be here.
New Hampshire
Time for a trip to Maine for a cut and turn it looks like to me!
Lookin good!
His corners are bigger than my whole garage!
Slednut10
Guru? That's funny!
It took 2 degree c bushings and 1.5 degree ball joint eccentrics to get 3.5 degrees total caster on mine so you might want to consider it Dave. I might still have to do it too.
It is a nice shop, Pete. I wish mine was that clean.
dave67fd
dave67fd
As usual I have to get one other car in for the winter. I'm moving crap around like crazy to see what works best. I'm sure gonna be out of room with 2 cars, a tub, frame and room left to work.
I have 7 deg. bushings but may decide to cut instead. I'm gonna prime it up and then need to do both R&P's. will figure it out then.
You could have a BONES garage cleaning get together. Just not sure who would come though.;D
