Daves 71 NH Build
71massbronco
Kind of slow. I am saving up for a new welder as well. I really need more fire power to get these welds to stick better. We just bought a new (used) Aviator, so funds are low right now. Think I am not going to have the Bronco for BYOB, again.
I pulled all the good hinges off my doors, took a little more paint off the grill. Small stuff that doesn't bother my arm. I also just ordered front wheel tubs and am going to put those in when they come in. Only major thing left is the window hinge/seal and DS floor pan.
dave67fd
dave67fd
That's sounds like good progress to me.....10 fold to the progress i'm making.
Doesn't matter as long as you show up. I don't even know if i'll ever get mine there but it's something to work towards nonetheless.
Yet to order anything. Still in the "getting rid of" mode. Light funds are going into the garage so anticipate late summer/fall before I at least pull the body.
dave67fd
dave67fd
Well, left work early and headed down to southern MA to check out a frame.
Met with Mike and had a nice conversation. Discussed and inspected the frame. It met my expectations. It is a 70' U15 frame. Other than the one affected area it will need a washer on one body mount and a new driver rear shock mount. Thats it, frame is really solid throughout and very clean. It has been blasted and etch primmered. Mike also gave me a dash which he just replaced on his 73, very nice truck i may add. The dash is in very good shape compared to mine. Also gave me a dash pad overlay in perfect condition.
Thanks again Mike.
Ohh and when i got home i received my Dennis Carpenter catalogs in the mail.
I want to thank Randy (Tasker) for spotting this one for me.
4lofun
It comes with engine mounts,too lol...looks like a good frame to me
migs
looks good Dave. if you need a hand making fixins for any of the holes let me know.;)
dave67fd
dave67fd
The mounts actually look pretty good but im sure i'll go new here. The suprising thing is that a couple of the body bushing that were left on it and the axle breather hoses have no dry rot as well as the tank mount rubbers like new. Also came with the brake proportioning valve.
Thanks B. I just got my gas last week, ordered from Cyberweld (thanks for that link) and spent a couple hours running some welds and getting familiar with the machine. I have to get some scraps to practice with. All i have at work is Aluminum and SS. We get our metal from Port City Sheet metal in Newburyport so maybe i'll call them to see if they can sell me abunch of diff. size scraps.
I plan to get the frame inside this week or weekend. Have to pull the conv. out to get it in. Also need to stop at HF and get a couple more dolly's. Once i get in and you have time for a quick visit you can give me some advice/pointers.:)
migs
Sure! no problem, be glad to. also, I'm sure I have plenty of good clean scrap you could use to practice. what thicknesses do you want?
dave67fd
dave67fd
B, that would be great. Anything you got your not going to use, scrap only, maybe random 20awg up to 1/4" or whatever. Thanks
tasker
all knowing of nothing
NH
Very cool, glad it worked out.....better get cracking BYOB is coming fast ;D
dave67fd
dave67fd
I'm trying to figure out what these frame brackets, mounts whatever they are and what they might have been designed/used for. There just in front of the rear shock mounts. There not used on my Bronco either. As a matter of fact there pretty much deteriorated.
dave67fd
dave67fd
So are others using this to mount a stock rubber bumpstop to or add aftermarket in another close area? Mount only looks specific for a stock bump stop.
Any pics?
deadfish
Dave, just cut them off.there is probably a hole under it.I put a piece of 3x4 angle in place of mine,then you can drill&tap to any bumpstop bolt pattern.
dave67fd
dave67fd
Thanks Dave. Good idea. I'll put that on my frame "to do list". Doesn't seem to be much for "rear" bumpstops other than a 2 hole flange type.
dave67fd
dave67fd
Got my frame inside on Saturday. Attempted to get in on Friday but had a problem starting my Fairlane as it had to move to get the frame in. Found the MSD box was bad so had to revert to hooking it back up in the stock config.
Anyway, removed what was left of the original body mounts and cleaned up the mount area as the frame was blasted with these still on. Also cleaned the area on the one mount to get ready to weld on a washer.
Bought a box of 5 washers from Mcmaster-Carr so if anybody neads a couple let me know or I can give you the p/n. The $4.20 for 5 is quite abit cheaper than the $13 or so for four the EB houses charge
A co worker sold me two cans of the Eastwood internal frame coat that he bought for his vette resto and never used for half price. I may buy another can or two.
migs
looking good Dave. I have some steel scraps for you, just need to coordinate a time to stop by.
