Daves 71 NH Build
dave67fd
dave67fd
Yeah huh. Thought it was cool. Should have bought a couple more but had limited luggage room.
Sorry. Didn't mean to leave you, Pete and Brian out of my response.. Got lazy and Just read the last message. Thanks all for thinking of me.
Hope to get back on the "71 soon. Cold is here so won't leave much outside work. Stay tuned.
71massbronco
It's always nice to come home to storm damage. Sorry to hear that. I need to get to a heater in the garage so I can finish painting the MC. Glad you had a good time!
D
dave67fd
dave67fd
Thanks D.
Well It actually happened just before we left. Power was back on late thursday night and we left late friday night.
Sucks without heat. I procrastinated a year and a half without it and just finalized it two months ago. I have a 40k propane bullet heater if you need one but they introduce alot of moisture and CO so not so good for painting or breathing without fresh air.
dave67fd
dave67fd
Trying to get my ass in gear with the Bronco so was able to spend a little time on it.
Pulled the PS box. PB blasted the pitman and with some pressure from my gear puller and a quick smack with the hammer she dropped right off.
Noticed two of the 1/2" frame bolts had a slight bend at the head end. Don't know if they were like that when the PO installed the PS. Wouldn't doub't it with all the other non-quality work he did.
Also got the 1/2" holes drilled in the frame for my shock hoops and put the hardtop on to get back a little room in the shop.
4lofun
just an FYI for you that those shock hoops require a 2" body lift or inner fender modification... ask Randy how he knows :p
I also need to remove my PS box because the inner side of frame by crossmember bolt is being pulled in and causing severe death wobble !!!! AGH !!!!!!!
reinforce the frame while its apart , I should have but said frame looks good????
fatboy
Glad to be here.
New Hampshire
just an FYI for you that those shock hoops require a 2" body lift or inner fender modification... ]
Not that one I do not think. That is a stage one, if you look at Randy's build you will see the brace to the spring bucket is several inches longer.
dave67fd
dave67fd
Back in the race to the finish! Glad to see you back at it!
Thanks Pete but i think I'll be the Tortoise and not the Hare;D
Brian,
Yeah Pete's correct. I will be going with prob. a 1" lift regardless. I also have a reinforcement plate for the PS that will be welded to the inside frame rail. May also add a brace as well but thanks for the heads up always have to keep thinking on these things.
tasker
all knowing of nothing
NH
have a set of 1" blocks if you need them Dave, won't be using them on mine
migs
good to see you back at it Dave, and I do believe that the tortoise beat the hare;D
dave67fd
dave67fd
Thanks Randy, blocks for suspension or body? will be doing a 1" body and 3.5" suspension lift. Will be going with full leafs, no blocks. Have blocks on it now and hatted them. If body let me know.
Thanks B. Ok then i'm the Hare:eek:
fatboy
Glad to be here.
New Hampshire
Pretty sure it is a body lift.
tasker
NH
he has the other side of it, cut blocks down....at least Deadfish did :cool:
dave67fd
dave67fd
Randy,
Ok thanks again.. but hold on to them for now. If you find another home for them in the meantime, please do so....who knows when i'll actually be needin em.
If you haven't yet found your Hydroboost parts maybe their with the blocks.;D
dave67fd
dave67fd
Nearly 4 months being dormant I hit a couple of small items to help get back in the groove.
Got back on the frame and fired up the welder to fill a small area at the bump stop that was lacking some thickness. Also made a template for the last area to be repaired.
Tackled the rear bumper tow hooks without much luck. Soaked them again but i'll hit them with some heat next time.
tasker
NH
ALOT there to soak! keep after it Dave.....proud of ya!
