So I finished the 4x4x2 install, and I noticed a little shake in the steering on bumpy streets. I then took the rig to the shop to have a set of 33" BFG A/T's mounted/balanced and an alignment done. The adjusted the toe-in slightly, and said the camber is a little off on the driver front, but can't be adjusted(without shim), so I was off. It's is now exponentially more shaky, and now the shaking seems perpetual, as in before, it would correct itself after a second. Now, if I don't hold the wheel, it's grows and grows until it's pretty nasty. I have searched and read up about the normal causes. I have no idea how old or crappy most of the bushings are. I had the wife steer while I crawled around, and I didn't see any noticable slop. I did however notice this.
The tie rod seems extremely gapped. I wanted to just snug it down, but I'm fairly new to steering componentry and geometry. The Driver side has no more than a few threads through the top on the nut, and the passenger already has much more through. Keep in mind the steering is maxed to the passenger side. The driver has little to no gap at the ball joint. Is this a large issue, or completely normal? If so, could it cause the issues described? Forgive me if this is day 1 stuff!
