Tires.
Before you do anything else to narrow it down, rotate yours front to back like pops did and take it on the same drive.
I might as well say again for the current record how I feel about Death Wobbles. It's always the tires that start it.
I actually hate to talk in absolutes, and act like I know it all and therefore there could be no other answers. But this one has a high level of confidence attached to it.
Ok, I know many people have fixed theirs with a new trackbar bushing, or welding up a cracked frame, or any of several other "fixes" but I say that those things are only allowing what is actually a harmonic setup by the tires. The tires are the only thing heavy enough and flexible enough to actually start the ball rolling, so to speak.
So if it's that repeatable by passing over the same stretch of road and each time getting the same wobbly result, it's a tire or tires.
If it was as simple as a bad trackbar bushing or bolt or mount, we'd have death wobble every time one of those wears out. But we don't. It's only a rarity nowadays it seems. Maybe that's because we're running fewer miles on newer tires, or just not driving ours because it's till a project in the garage, or we have better tires, but for whatever reason we don't see as many DW's as we used to.
And that's a good thing!
Many things can make it worse, or start and/or stop at a different frequency, but the tires are causing the trouble.
Might be a bad internal belt (most of the ones I've been involved with) but internal issues along with strange tread wear can set the stage.
I was in a truck once that didn't have it one minute, then right after curbing the tire turning into a local Taco Bell, got it big time right after driving back out and never got rid of it until he rotated that tire to the rear axle.
Of course, if it's more than one tire, like the case on a buddy's '70 with very worn out and tired 33x9.50x15 Swampers, rotating isn't going to help. In his case it was at least three, if not all four tires. After much hair pulling, and tire rotating, new tires finally cured it.
In his case, the PO he'd just purchased it from had found a way to temporarily overcome the DW's enough to turn them into just a controlled wobble. He'd installed two stabilizer shocks, mounted in such a way as to actually bind the steering linkage so it was hard to turn. It was so tight that the oscillations could never quite reach the level of Death Wobble.
He purchased it in Los Angeles and drove it home. Because it was acting so badly, he asked if he could stop by here (we'd never met, just talked here on the forum) and drove it all the way from Los Angeles to my house to see what was up with the thing. Shook, rattled and rolled, made funny noises, was hard to steer and generally just felt weird. But at least got him here.
We found the bound up steering linkage and removed one stabilizer, then drove down the street to see if that fixed his hard steering.
It did... But we only got about 1/4 mile away before things started going to hell and it did the DW two-step and dancing all over the lane.
He had to change his underwear after that! Until that moment he'd never heard of DW's.
Sorry for the novel, but I still say try the tires first. Then go to Plan-B if it's not fixed.
You can even try one tire at a time to help narrow it down.
Of course, it never hurts to check all that other stuff anyway. And now that you've shaken things up a bit, it's even more important than ever to inspect for loose components or cracked welds or whatever is not good.
Good luck.
