Death Wobble
shinyisme
I've read several articles on the forum on death wobble. My wobble is frustrating because it's only at certain stop signs and stop lights while applying the breaks; green light no problem. The wobble continues even after braking pressure is removed and I downshift to slow down. The fact it's only specific lights/stop signs lets me eliminate rotors and calipers (for now). If anyone is from ABQ culprits are Gibson/Carlisle and Menaul/Wyoming intersections. I've checked other low hanging fruit alignment, tire pressure, and wheel bearings. Next step is getting my tires balanced. BUT my buddy just got a go pro and I wanted to test it out and thought I could use it to help me trouble shoot. Looking at the passenger side suspension fast forward to 4:15 for the DW. I didn't see anything obvious, except the tremendous shaking. Apologies for the orientation, new toy.
https://youtu.be/uonj7QOr4UY
I'm wondering if I just have a Tacoma Narrows Harmonic issue.
Applicable specs:
1969 original 302
33" Tires
3" lift
Front Disc brakes
AxlesUp
Collierville TN
is it just me or is your radius arm mount moving around a lot independently of the frame?
i think its just an illusion due to it lining up with the leaf spring.
Looks like the wobble is coming from the driverside. can you zoom it out more and make another run or point it to the driverside stuff?
anyway i'm a total nerd, i could watch chassis cam all day LoL
dblupcobb
Pensacola
I am having a similar issue. My wobble has driven me nuts for years. I even got new tires had alignment done and tires "trued." The problem has gotten progressively worse, to the point I am planning on starting over on my suspension and installing a new lift kit. One thing I plan on trying, is turning my rotors. With mine, it definitely feels like the source is from the driver's side. I'll let you know how it is after I have the rotors turned.
Pops68
Bronco Rookie
Bazetta Township
Just fixed my death wobble issue this past weekend.....first tried air pressure - no help. Then tried the next easiest/least expensive fix suggested to me - ROTATED the tires front to back......worked like a charm (KNOCK ON WOOD!!!) so far. Try it???
Pops
S
shinyisme
Thanks for the replies so far. I'll get better video today after work: correctly oriented and of the driver side if I can't get both at once.
Pops, I'll try both tire balancing and rotating today. Sadly, I wont know what fixes it, but 2 birds 1 stone and all.
Axle, I'll take a closer look radius arm mount as well.
ENDLIFE
Let me first say that I'm sorry for your death wobble issues. I have had to fix this condition 4 times in the shop I used to work in. First, like Pops68 said, we look at the tires, check for wear patterns, or any balance issues. Second, we would check ALL the components of the track bar system, and replace any overly worn components. Lastly, if all else fails, we pull the whole front end, and in two pf the occasions we found that the radius arms do not touch the ground at the same time when rotated in either direction.
I hope you find your issue. Death wobble is an unsafe situation. If the people of the Classic Broncos community cant help you. . . NO ONE CAN (JK).
hotrodtim68
Bushings
Trac bar bushings were bad for me. Replaced original rubber with poly. My front "C" bushings were also changed to poly. This is a must for longevity.:cool: Of course all front end components must be looked at closely and examined . Any combination of things can be at fault. Take the time . Be safe on the road.
S
shinyisme
Got my tires balanced and rotated today. There was some uneven wear on the front two tires, but the rear now front tires are good to go. Mechanic had to add 7 ounces to the once driver side front tire.
Here is a much better video of the wobble. I could not duplicate the severity due to traffic today, but it's still there. Same spot on Gibson/Carlisle intersection and nowhere else.
https://youtu.be/Uelc5ARJ7XE
bronconut73
Mine was track bar bushings. That was 30+ years ago. Funny how some things never change....
Get under there while someone else is firmly swinging the steering wheel back and forth. Just look closely at everything while they do it.
Check that Trac bar closely. Its bushings are a common culprit.
savage
Bronco Nut
Renton
Its hard to tell in the video, but look at the up part of the track bar, where it mounts to the drop bracket, that's a common spot for the bushings to wear. When it's on the ground have someone turn the wheel back and forth, and watch the track bar ends for a lot of movement, and watch the tie rod end's and drag linkage.
Tires.
Before you do anything else to narrow it down, rotate yours front to back like pops did and take it on the same drive.
I might as well say again for the current record how I feel about Death Wobbles. It's always the tires that start it.
I actually hate to talk in absolutes, and act like I know it all and therefore there could be no other answers. But this one has a high level of confidence attached to it.
Ok, I know many people have fixed theirs with a new trackbar bushing, or welding up a cracked frame, or any of several other "fixes" but I say that those things are only allowing what is actually a harmonic setup by the tires. The tires are the only thing heavy enough and flexible enough to actually start the ball rolling, so to speak.
So if it's that repeatable by passing over the same stretch of road and each time getting the same wobbly result, it's a tire or tires.
If it was as simple as a bad trackbar bushing or bolt or mount, we'd have death wobble every time one of those wears out. But we don't. It's only a rarity nowadays it seems. Maybe that's because we're running fewer miles on newer tires, or just not driving ours because it's till a project in the garage, or we have better tires, but for whatever reason we don't see as many DW's as we used to.
And that's a good thing!
Many things can make it worse, or start and/or stop at a different frequency, but the tires are causing the trouble.
Might be a bad internal belt (most of the ones I've been involved with) but internal issues along with strange tread wear can set the stage.
I was in a truck once that didn't have it one minute, then right after curbing the tire turning into a local Taco Bell, got it big time right after driving back out and never got rid of it until he rotated that tire to the rear axle.
Of course, if it's more than one tire, like the case on a buddy's '70 with very worn out and tired 33x9.50x15 Swampers, rotating isn't going to help. In his case it was at least three, if not all four tires. After much hair pulling, and tire rotating, new tires finally cured it.
In his case, the PO he'd just purchased it from had found a way to temporarily overcome the DW's enough to turn them into just a controlled wobble. He'd installed two stabilizer shocks, mounted in such a way as to actually bind the steering linkage so it was hard to turn. It was so tight that the oscillations could never quite reach the level of Death Wobble.
He purchased it in Los Angeles and drove it home. Because it was acting so badly, he asked if he could stop by here (we'd never met, just talked here on the forum) and drove it all the way from Los Angeles to my house to see what was up with the thing. Shook, rattled and rolled, made funny noises, was hard to steer and generally just felt weird. But at least got him here.
We found the bound up steering linkage and removed one stabilizer, then drove down the street to see if that fixed his hard steering.
It did... But we only got about 1/4 mile away before things started going to hell and it did the DW two-step and dancing all over the lane.
He had to change his underwear after that! Until that moment he'd never heard of DW's.
Sorry for the novel, but I still say try the tires first. Then go to Plan-B if it's not fixed.
You can even try one tire at a time to help narrow it down.
Of course, it never hurts to check all that other stuff anyway. And now that you've shaken things up a bit, it's even more important than ever to inspect for loose components or cracked welds or whatever is not good.
Good luck.
savage
Bronco Nut
Renton
I agree the tire's are the first thing you look at. My father in law had his tire's rotated on his 2006 dodge 4x4 dually diesel, never had a problem before, then the wobble started after the tire's were rotated, ended up being a tire out of balance, what funny it was the inside tire in back, never had a problem intel it was put up front. Here's Pops68 thread about his death wobble and his fix http://classicbroncos.com/forums/showthread.php?t=267438&highlight=death+wobble
