- Jun 4, 2002
- 35,512
Thanks everyone for your thoughts and suggestions.
it sounds like a junkyard 4R70W with the Bauman computer is the way to go.(not ready to go EFI yet)
First order of business is some extended radius arms so in the meantime I'll keep an eye out for V8 explorer's being parted out in craigslist.
Broncobowsher - you mentioned engine braking and OD. The 4R70W is a lockup transmission right? does that mean you can lock it up in low range?
how does the calculation work for engine braking?
1st - 2.84
Atlas - 3.8 (may go with 4.3)
gears - 4.88
52:1
I've always multipled that by ~2 to get my final crawl ratio to account for the torque converter so I would have about 100:1 crawl but how does that work out for engine braking?
I agree... i'll miss putting the 435 in granny gear and Dana20 in 4-low and creeping down an incline while the guys w/ automatics behind me have their foot mashed into the brake the whole time.
That crawl sounds right. Very close to mine but I only have 3.15 in the transfer case.
If you find an Explorer ('98 to '01) V8 that has all the goodies built in. Find one with AWD and the Atlas will bolt right on.
Sorry, the 2WD tailshaft is different then the 4WD. Can't just swap the tailhousing, doesn't work that way.
The Baumanator lets you program what gears the convertor locks in. One of my tricks is I added another button to the floor that lets me lock the convertor at will. Push the button (hidden under the carpet) and it locks up. Idle up steep hills at 600RPM with an automatic without touching a pedal. With that much gearing, idle right back down it as well.
The 2:1 multiplier only comes in when you have the gas mashed. Does not work for engine braking. This is why you always see people with there C4s complaining that they have no engine braking. Well they are wheeling with 20:1 crawl abusing the convertor to get into the 40:1 to get over stuff. The less you rely on the convertor to make it over stuff the better. coming up to a rock or a tree, digging deep into the throttle then popping up over the top is a sign of not enough gear and too much use of the convertor. Even without locking the convertor I can usually just idle up to something and walk over it with no or only a little throttle, just like a granny on the 435.
The 4R70W has about 14" pan length, the E4OD is about 20". The 4R70W will have 3 eletrical plugs; one on the single shift arm, one on the case (speed output shaft speed sensor which is not a vehicle speed sensor), and one going into the case at the rear passenger corner just above the pan. AOD will have a single plug on the very top of the case above the shift lever and the shift lever will be a double arm (other for the TV).
