Dip stick measurement
Cool67
Got a 74 bronco without a dipstick . I have another dipstick that is not correct for the bronco, came off another vehicle ,and I want to cut it to the correct length. Can someone pull theirs out and give me a measurement from the edge of the cup to the end of the dipstick so I can cut mine. Thanks in advance!
Sounds like you have an open dipstick hole. Is it on the timing chain cover, the passenger side of the oil pan, or the driver's side of the block. All were factory dipstick locations in different applications. I could assume you have a stock Bronco pan and dipstick, but so many have been swapped over the years that is likely a bad assumption.
If you can confirm that it is truely a stock Bronco pan, do an oil change, 6 quarts with filter. That will be the right level and adjust you stick to match. This will work even if someone did something wrong with the tube. Or the tube is from an odd application we are not thinking of.
C
Cool67
Stock oil pan dipstick tube threads into the passenger side of the oil pan
Pops68
Bronco Rookie
Bazetta Township
I may be wrong about this, but wouldn't you be cutting off the part of the dipstick that has the measuring (full) marks on it??? How would you then check the oil level for correctness??
An old neighbor used a piece of thin cable. TIG welded beads on it at the full and low marks. He was a really good welder.
Jdgephar
I used an engraver on mine after a fresh oil change. Well, first one quart low, marked, and then full and marked again. You can use anything you want....drill a small hole, center punch, etc.
SLOWnEASY
San Diego, Ca.
If the dipstick is not from another Bronco then you need to be concerned about both the tube length as well as the dipstick length. If not from a Bronco I would do as Broncobowsher suggests and do an oil change with filter. But I would only put 5 qts of oil in.
Drive the Bronco around the block a few times and then check and mark the stick. That is your 1 qt low mark. Then add an additional quart of oil and mark the Full mark. Many people are not aware that the space between the full and add points on the dipstick represent 1 qt of oil.
Also many years ago I tried to center punch an engine oil dipstick and the stick just shattered. So I would suggest using something like a dremel with a small grind stone to mark the stick instead of trying to drill.
catfan
My 75 is 13 1/2 to the full mark but I still wouldn't mark it until you know you had the right amount of oil in it.
ntsqd
heratic car camper
Upper SoKA
I had to make one for a different engine. I did what Broncobowsher suggested. After measuring to the wet line I cut the dip stick near the top, over-lapped them, and welded them together on the sides only.
jamesroney
Fremont, CA
I don't normally post on things like this, because it just reinforces my world view on humanity.
So 14 replies, and still no answer. (13.5 inches is a great answer, and the number you really need, but not the answer to the question you asked.)
Such a simple question with so many different answers. And I'm going to say it: @Broncobowsher @catfan @chuckji and @ntsqd are all giving you good advice, but there's more to the story.
So here's the rest of the answer, and why you don't want it.
In 1966, Ford engineered the dipstick for the 1966 model year pickup and Bronco with engineering number C6TE-6750-F. This dipstick ran in the Early Bronco until 1971, when it was replaced by the D1DE-6750-AA. That D1DE-AA stick ran thru the end of production. The screw in style tube happened in 1973, so you know that the 1971 stick design worked on both push in, and screw in tubes.
Some key measurements from a factory correct C6TE-6750-F dipstick. The distance from the end of the stick to the "add" mark is exactly 1-1/2 inches. The distance to the "full" mark is 1-15/16 inches. The distance to the bottom of the bell is 16 inches, and the question you asked: The length of the stick from the bell stop to the end of the stick is 16-5/8 long.
But it is critically important to understand one thing. The 289 engine in the 1966 Ford Bronco is a passenger car engine, and has an oil capacity of 4+1 Quarts. So when the design specification was interpreted by the Truck design authority, the dipstick was calibrated for the passenger car oil capacity of 4+1= 5 quarts. So the 1966-1970 Bronco stick is calibrated for 5 quarts, but the actual design capacity AFTER durability testing was 6 quarts. So every Bronco from 66-71 reads WAY above "full" when serviced with the correct 5+1 capacity. Which is why EVERY Bronco owner doesn't trust the stick, and practically every one has an additional mark, or a hole, or some mod, and they ALL think they have the wrong stick. Then somebody figures out that they can fill the Bronco pan at 4+1, and the stick reads right. The 1/2 of the Bronco community says the correct capacity is 5 quarts. But of course everyone knows the capacity is 5 quarts. (Plus 1 for the filter) So everybody ends up talking over each other, and no one knows the correct answer. Except me. And now You.
So, the correct capacity of a 1966-1977 Ford Bronco is 6 quarts with a new filter, and the correct fill level is exactly what @catfan told you, and it is NOT what I measured for you on my factory correct dipstick.
But since @ntsqd and @Broncobowsher are on this thread, I have to say more. And the more is this. If you add a quart of "excess" oil to a standard front sump passenger car pan, it will indeed elevate the oil level perilously close to the crankshaft, and result in windage effects from the reciprocating mass. BUT the rear sump Bronco pan has a significantly larger cross sectional area. So the fill level rises less with the addition of a quart. Somebody postulated that when climbing up steep inclines, the oil pump could starve with the engine at high rpm, and an additional quart was specified. But this is of course nonsense, because the Bronco is rear sump...so climbing would keep the rear sump full. So the failure mode would have to be descending on steep inclines at high RPM, such that the oil level starves the rear pickup. To which I conclude, every early bronco with a 6 quart pan should be equipped with a windage tray. Or it should be operated at 5 quart fill. Or simply change the dipstick to the D1DE-6750-AA and send it.
pics to follow.
jamesroney
Fremont, CA
But wait...there's more.
So now we know why every Bronco owner recommends calibrating your oil dipstick. They tell you to fill your engine to 6 quarts, add a new filter, and mark the stick. But that advice is 1/2 baked.
The problem is that the typical Ford dipstick has varying degrees of angle, depth, and fill level, based on the installation. Here's a picture of 4 different small block Ford dipsticks. And there is a big difference between "add" and "full" depending on application. (note that the factory C5TE-F Bronco stick had 7/16 inch between ADD and FULL.)
So the proper technique when calibrating your Early Bronco dipstick is to do what everybody else says...Except do this first:
0. park on a level surface.
1. Drain the existing oil and remove filter.
2. Install new filter, and add 5 quarts of oil.
3. Start the engine, wait until the oil pressure builds.
4. Remove the dipstick. make a mark at this level. This is your "ADD" line.
5. Add 1 additional quart.
6. Remove the dipstick, and mark this level. This is your "Full" line.
If you are a cheapskate like me, it is perfectly OK to re-use the old oil as long as you measure it carefully. At $10.00 per quart, a few drops either way won't hurt anything. I'm leaving now.
I once owned a Bronco that had double dipsticks. It was a car engine but a Bronco pan. They did not agree. I forgot which one won.
I just picked up an old Bronco engine for a boat project. Same thing. timing cover stick and a Bronco pan. Came from a '67, 289 block. But it is missing the Bronco dipstick, so I can't reference that. And the engine is just sitting on a pallet anyway, so not at the right install angle. It is old enough that the Fram PH8A filter does NOT have the black sure-grip paint on the end of it. That dates the last oil change before 1999. The oil inside looks like new. Likely newer than my other engine that has the AC labeled oil filter that was last used in '95. Keep collecting old engines that have been sitting forever. That 221 the dipstick going into the pan on the driver's rear corner. I can't have anything normal.
SLOWnEASY
San Diego, Ca.
Just looking for a measurement…, I then mark it with a dremel
Our concern (or at least my concern) is you stated in your original post "I have another dipstick that is not correct for the Bronco, came off another vehicle"
Are you saying that you still have the original dipstick tube but just not the original dipstick? Because my assumption in reading your original post was you have both a different dipstick and dipstick tube as a set. And if that is the case then nobody is going to be comfortable just giving you just a measurement. Because a measurement of 13.5 inches might work if you have the original dipstick tube. But if you have a different dipstick tube and it is an inch or two shorter or longer that a stock tube, then the 13.5 inches measurement is completely worthless.
As JamesRoney says the answer to your original question is 13.5 inches.
ntsqd
heratic car camper
Upper SoKA
...... I can't have anything normal.
I feel that pain. I'm learning (not very well or very fast) to not put myself in those positions, but sometimes it can't be helped.
I learned long ago to put the suggested pan capacity worth of oil in the engine, let it sit for a while and then check how that marks the dipstick.
@jamesroney 's 7 step plan makes the most sense to me. Quit worrying about whether or not the dipstick is the correct one and check that it's accurate or re-mark it so that it is. Worrying about correct or not is just spinning wheels and not getting it fixed. The only time to worry is if it is too short to have the 'ADD' mark on it.
I also learned long ago that those bell-caps are just about worthless as a true dust seal. The new dipstick & tube combo that I made has a compression union at the top of the tube. Lower union nut is wrench tight, top union nut was tightened with a wrench and then loosened to finger tight. Upper nut and union ferrule go with the dipstick. The rest of it stays on the tube. The finger tight union nut is a LOT more dust proof than the funny little cap.
C
Cool67
I have a nos correct tube for my 74 302 bronco but the dipstick is not correct It is from a different vehicle .I just need that measurement
