KANE
Hey to all,
So I just replaced my timing chain, Timing Cover, water pump, Oil Pan Gasket and cleaned and painted everything, fired it up and.......unfortunately it leaks oil....only when running and leaks more when you rev it. Seems to be coming from the Crank Seal.
After looking into it, I may have installed the crank seal wrong. the "ford" TC Cover had it installed from the back side so I did the same on the New Dorman Cover. Also...I didn't lube the seal...I know I'm a dummy....but can anyone tell me if the seal goes on the outside or inside..and by not lubing the seal, did I smoke it? Sucks that I have to do this over again, but at least it will clean and bolts will come right out!
Thanks!!
Mike
Thanks!!
Mike
