I have a 73 and I’m running a rat transmission and 3 on the tree.
Do you have the “ambient switch” installed and working? That’s the sensor in the door A-pillar and an attachment on the transmission.
I believe it does something to the ignition timing when you’re in certain gears.
It was a 73-ish only item.
The duraspark I’m running isn’t working out.
Why not? What is it doing?
Since you have a ‘73, any Dura Spark distributor was swapped in. Maybe the PO installed one with a less than optimal timing curve?
It might not be considered the ultimate distributor by some, but many of us think they are very good.
Certainly plenty of options out there though. Anything for a 302 that has the correct gear for your camshaft will work.
Do you have the stock original type (flat tappet) cam, or has the engine been updated to have a roller cam?
What should I use instead? What fits?
Up to you really. Lots of options.
Already had one recommendation here for HEI but many of us avoid those, not so much for the quality because that can be gotten around, but for the sheer bulk of the distributor cap.
