Diving into sanding Barney
kat
Bristol
Although I consider myself mechanically inclined, I never messed around with body work. And after searching google/youtube I am now a master;D. Joking.
Ol Barney has a couple rust spots that I have ground out and have bought POR 15 to stop it. The majority of the body is pretty straight with little or no Bondo. Im not looking for a showroom quality paint job, I just want to change the color of it and hopefuly next tax season I will have the money to pay someone to spray it but I want to do as much as the work myself as possible to save money and to say "I did it"
I know a lot of a good paint job is in the body work. I have a electic orbital sander that Im going to run over it to get some of the rough out of it (240 grit?) But I have read that block sanding is what needs to be done at the end. With that said I was looking at some block sanders from Eastwood that offer different contours in the blocks. And as you all now there aren't a lot of contours in our Bronco's. So this brings me to some questions.
1=Is my approach to sanding right? (orbit with 240 then go finer and end with blocks?)
2=When it comes to block sanders, do I need 7 different sizes or just one long one for all the flat panels? Or maybe one long one and one round one?
3=Im doing my sanding outside (no overhead lights) will I need some sort of light to see ripples or will a guide coat and block sanding do the trick?
Again I'm not looking on a Show room paint job like I see a lot of Bronco's on here, but I want to do the best I can with the little resources I have. Any tips or links will be great. Thanks
Here are the Blocks I was looking at
http://www.eastwood.com/dura-block-shorty-5-pc-kit.html
thegreatjustino
Red Head Grease Monkey
Stockton, CA
So many questions here. How many layers of paint are on it to begin with? Are you planning on shooting it with primer a couple of times and then block sanding? Are you just trying to sand it down to paintable stage utilizing the existing layers without priming?
Personally, I'd sand with the orbital down to the original layer of paint. Spray a high build primer, guide coat it, then sand till all the guide coat is gone. This at the bare minimum.
How many times you want to primer and block sand is up to you. I did my '65 Mustang five times and the paint still isn't perfect. If you're concerned about waves, you need to wet sand at some point and look for the waves in the shiny primer.
68stang73
wash it with dawn soap and rinse then 80 grit that down to original paint and feather out all the rock chips. I like to use Clausen All-u-Need. Its an extreemly high build self etching primer AND sealer with zink and built in guide coat. This stuff is tough as nails. Then block sand the guide coat(w/180) will revile the high and low spots. Stop when the primer just breaks into the original color. Do that on entire truck, then apply more all u need and repeat until its one uniform color, step the paper grit up in size each time. Your final wet sand should be about 600 grit. Wash again then use sealer wait 45 min then base and clear. Look up videos on how to block sand. I would say a 6" and a 20-24' block sander is all you need. This is just a quick rough idea and im sure there will be more input, But that where i would go start with.
kat
kat
Bristol
It is not the original paint. If I was to guees it was repainted 10 years ago. There is still clear coat on most of the Bronco, worst part is the hood where the paint has faded.
I wasnt clear before but I dont want to take it to bare metal, my opinion the paint on it is in good shape, no chipping or flaking.
80 grit? that is pretty aggressive isn't it? I like the idea of using the primer to find high and low spots. Ill look into the All U NEED primer. I havent seen that in my local stores, but Im assuming its out there on the net.
I have done my homework on proper block sanding. I just want to make sure I dont buy stuff I dont need.
needabronco
Prescott/Farmington
Go to your local automotive paint supply store and get your primer and paint supply there. When/if you gave problems or questions they will be more inclined to help you out. Personally I'd tell them upfront that you'll buy ALL of your equipment and paint from them and ask if you could get a 'shop' discount, it will likely be cheaper than shopping around.
For primer you want a 'direct to metal' type primer, there are several brands that are and can also be mixed as a high build and as a sealer. U-pol primer is very good and its fairly inexpensive.
A cheaper faster way to get good results is to use a poly body filler on the wavy or flat spots first. It will save you on sanding and priming. Start with 80 grit work to 180, 120, and 320 before paint. 600 and up is for cutting your clear coat for that show car/mirror finish.
kat
kat
Bristol
Thanks, good points. I failed to mention I dont have air compressor and was going to rattle can the primer. So hopefuly I can get that in rattle can. Can you get 80 grit for a orbital sander?? Only thing I seen that on was for my side grinder.
needabronco
Prescott/Farmington
If you rattle can primer don't waste money on a good paint job! Nothing wrong with rattle can, but if you use rattle can primer just do a Krylon paint job to. It takes 12-14 cans BTW.
kat
kat
Bristol
Well, my plan was get the body good and use a rattle can to prime it, and when I take it to get it painted have them put a good primer on top. Is that not a good idea??
68stang73
Well if that's all your going to do just save yourself a headache and money and just liquid wrap it. Plasti wrap. Easy cheesy
68stang73
I do a little bit of painting.
[/URL][/IMG]
68stang73
The Red Victory has won 12 Best of shows this year so far. The pink Harley is my wifes and she has won best of show to all the ones she has gone to as well.
[/URL][/IMG].
kat
kat
Bristol
Very nice man....You want to visit Florida cheap??? Got a house on a lake...hour away for the Worlds most beautiful beach.
So even if I smooth the body and just rattle can primer and then let the painter prime over it will be a waste of time??? Just trying to save some money...Like I said Im not looking for a award winning paint job....just different color
68stang73
Yeah don't waist your time with rat can primer. I don't think any pro shop will lay any material over rat can anything.
kat
kat
Bristol
Oh some day we do plan on a FL trip.
When you do let me know, If you want relaxing beaches, North Florida (where I live) is the place to be. Ill give you some local spots to go.
Ok, so let me re-think my sanding procedure. If I "scuff" the paint, get the body panels rusty places fixed, use Bondo in low areas and use rattle can primer just for the effected areas and I wait 5 months and take it to a local shop for him to prime AND paint it, will that be OK? Meaning would a shop work with that?? And will my paint be OK scuffed up that long? Sorry for silly questions...
68stang73
Regular primer and bindi will soak up moisture and rust your metal up. Resulting in blistering your paint. I would talk to your local shop and get suggestions from them. But honestly I would suff and prime the rusted areas and then plasti dip the whole truck. Then you can drive it saving up the money to get it done correctly. And yeah relaxing beach would be great. I just rented a lake house for a week here in Kalispell MT, and that was a great time.
DaveLev
+1 on florida beaches. Huge fan of Clearwater on the gulf side. Tampa is okay, too.
kat
kat
Bristol
I looked into the Plasti dip, and I don't think I want to go that route...3-5 years is all they are guaranteed. I have vacation next week and Im going to take it by a guy and talk to him about "the best way to prime" I might even pay him to throw a coat of good primer on it for me.
And yes, when and if you come to Florida make sure you stay on the Gulf side. Clearwater is nice but Im further North. Mexico Beach, Destin, anywhere along 30A is where to be.
