Got the replacement shocks installed. Thanks for sending them out so fast.
Unfortunately, I am still not happy with the amount of body roll from sudden turning movements. Ordered a set of monotube shocks to test and see if the extreme roll is reduced as compared to the hydraulic shocks.
Actually, I have considered multiple possibilities to fix this roll issue.
The first was a anti-sway bar. Considering how soft this system is, I am surprised an anti-sway device was not included in the first place.
Next, I considered multiple iterations of shock options between hydraulic, nitrogen, and monotube among the four different positions and even considered going inboard only.
For now, I am going to try the monotube on the outboards to try and handle some of the roll since they are 250 psi and leave the inboards hydraulic to help dampen some of the vertical movement over the axle.
If that doesn't work, I plan to replace the inboard hydraulics with nitrogens. Of course, if all that turn out to be overkill, I may end up ditching the monotubes and running nitrogens all the way across.
FWIW- My RTI score increased from to 1,160 to 1,436 with the pesky outboard shocks removed thus allowing my rear wheel to fully compress into the wheel well.
More to come....
