Levisbronco
How do you put fluid in the rear dif. I was leaking out of the pumpkin so I put a new seal in and now I need to fill it. Thanks.~Levi
Amac70 said:wouldn't it be easier to go through the breather hole if you didn't have a fill hole then pulling the axle out and putting oil in that way.
Skuzzlebutt said:My book calls for 5 pints. A locker or L/S won't make a difference. With a clutch type L/S you do need to use an additive with the GL. Some GLs have the L/S stuff already in it but most don't. It would be clearly labeled if it did.
