Dyno'd the 77 today!
blazinchuck
after some aggravation with the steering column, decided to ride out to my buddy's shop. they wanted to put the bronco on the chassis dyno...so i said ok
she put down 210hp/245tq...i was hoping for more, but thats still not bad,
anyway to figure out what my loss is going thru a nv3550,d20,9"(4.56) and 33" tires? so i can kinda put a number on the motor.
they printed out my run, but my scanner is down.
fuel pressure held 42, and the wideband showed my running a touch rich...i think 12.8
fordtrucksrule
when i dynoed mine i got 298 ftlb torque at 1900 rpm ant 160 hp at 3500 rpm thats with a 351w and 35" with 4.11:1 gears and lockers
blazinchuck
blazinchuck
if im looking at my printout right..looks like my hp came in round 4500rpm and torque round 3700rpm...we ran it up to 6k
Viperwolf1
electron whisperer
Your camera is up. Take a picture of the printout.
Sent from my MOTWX435KT using Tapatalk 2
Those may not be stratoshperic, but those are some pretty decent numbers you guys. Even 210 to the rear wheels is none too shabby. Thinking that maybe that's 260+ at the engine? I forget how much loss there is, but it's not chicken feed with these rigs.
I bet all of your engines run pretty strong. Those are some pretty sweet torque numbers you got there fordtrucksrule! Almost 300 lb at just under 2000 rpm? Sheesh. Strong out of the hole I'm guessing?
Chuck, with those number, I bet if you fine-tune it some, without changing any hardware you'll be pretty happy with the way it feels. Just get it outta that rich range a bit and it should be sweet. That 12.8 sounds pretty rich to me. Maybe I'm over-thinking it, but isn't that quite a bit off of the sweet spot?
broncnaz
Sounds about right for a 306 really the cam is to big IMO as far as the power band shows anyways. 12.8 is fairly close to what you want for max power. The common 14.6 or so is for ecomony. Big tires will scrub off a bit more HP than normal but overall I think paul is about right on the 260 hp or so at the flywheel.Although I would think that combo would be pulling over 300 at the flywheel. Total parasitic power loss is probably around the 20 percent range about normal for most manual transmissions even the newer ones. autos usually lose closer to 30%.
Hard to say how much power big tires and a soft suspension eats up tho.
xcntrk
NOVA
The general rule of thumb is around 10% drivetrain loss for your typical tranny/diff setup for a RWD car. AWD's can range as high as 22%. So I'd guess somewhere in-between for the transfer case and big truck rear end.
chuzie
Most of what I have seen with the street cars is about 15% loss with a manual trans. We obviously need to bring that number up for the tires and rear end gearing. I'm thinking any less than 20% is out of range.
bmc69
I have actual numbers from flywheel and rear wheel dyno runs on the engine in my '69. A few things were different; the flywheel runs were done with the "shop's" headers and a 4V carb (Demon) and the rear wheel runs were with cast iron manifolds, dual exhaust and throttle-body injection..and on 39.5 IROKs.
The difference between the two was about 28%!! 246HP at the rear wheels versus 342HP on the engine dyno. I would only attribute maybe 3% of that to the exhaust system..so 25% is the basic reduction I use for typical driveline losses on this type of 4x4.
210 RWHP is none too shabby, for certain.
bronconut73
I was going to say that I have seen near 20% loss in various street rods.
So I bet BMC is dead on for EB losses at 25%.
bmc69
"Actually measured" is about as close as ya get..methinks. :D
I was expecting over 20%..was a bit surprised at 28%.:-X
But using 25%..that would put the OP's engine at about 280HP at the flywheel..
Bronco Biff
....So how did your 0-60 times look? Must have been strong enough to pull your steering shaft loose!!! Maybe you should lean your seat back up some so you can lean on the seat instead of hanging off the steering wheel while your rowing through the gears!!!!
blazinchuck
blazinchuck
haha...no doubt biff
took me a while to figure out the dakaota digital...but i got 2 runs off and the 1st was 8.5 followed by a 8.4. the roads were still damp and it spun like heck. maybe ill try a better run on dry road soon
bronconut73
Well, "actually measured" on one EB could be a bit different on another. Different tires alone could effect the results. I think your 28% is on the high side of the spectrum. I am not completely certain 25% is even that accurate for "every" EB since so many are set up sooo differently but for the way "most" of us are set up 25% is probably a good round number to go with.
bmc69
Well, "actually measured" on one EB could be a bit different on another..
Of course. And in fact, I was going to have another run done with a set of bone stock tires and wheels to see how much the IROKs cost in HP loss. Still plan to..but its way down on the "to do" list.
And..an EB with an automatic is going to have higher losses than a manual tranny like mine, even if it has a locking convertor..
I liked the Mustang Dyno that a local speed shop used because it attached the drive rollers directly to the wheel studs on the axle. No variation then from different types and sizes of tires.
It's still nice to know what's actually being put to the ground, but with this method you can at least see what's getting through the rear differential and out to the tires.
And no slippage variations to account for.
