Early Bronco Build 5.0
Bronco6684
Hi, building a 76 Bronco from the frame up.
I have purchased a 5.0 Explorer Motor. The Bronco has stock 3:50 Gears, with 33" tires, would I be better ahead to go with the original plan of mating it to a AX15, (I have The AX15 but would need the conversion kit), or would it make sense to mate it to the C4 Auto (I have everything for that but tranny would need to be rebuilt). One of my issues is with the Explorer 5.0 I wouldn't have a transmission kickdown? I could lose the fuel injection and run a 4 barrel. (I have a new intake but would need a new carb).
Any extra pieces could be saved for another build
All advice would be appreciated
Personally I would not try to go backwards with the C4 if you have a perfectly good 4R70W already mated up to the explorer motor.
I would also not go backwards by trying to get rid of all the existing stuff and go to a carburetor, when it’s the fuel injection that makes these engines so desirable in the first place.
Of course, people do just that and I’m sure it works out well. Just seems a waste to me. But then I’m biased because I have a stock explorer motor in mine.😁
I also have something similar to the AX 15 going to go in the other one.
The big downside from what I see in your description is the 33 inch tires and the 3.50 gears.
If you had 4.11 gears the C4 would begin to make sense. So with the carburetor. But with the great running EFI and the lower first gear of either of your other transmission choices, you might get away with the tire size and your ratio combination.
Otherwise I think you’ll end up with a semi-slug and be very disappointed.
B
Bronco6684
Thanks I didn't get the 4R70W plus the computer from the Explorer had already had the security removed as well as the programming for the auto trans deleted, which pushed me towards the AX15, which I now have, my concern was that my 3:50 gears and the OD might not respond well together, there are the smaller issues of acquiring a proper column and pedals but those are minor issues
Timmy390
Conway, AR
Unless you're just itching to have a clutch.....go with the C4 (assuming you pulled it out of the Bronco) and save the expense of the adaptor kit and all that comes with changing transmissions. You need gears IMO no patter what trans you run with 33 inch times. With the C4, 4.56 or 4.88 would be my choice. You don't want to lug an auto. It generates heat and heat kills.
Trans swaps are great but can get expensive. Adaptors, crossmembers, drive shaft modifications, etc.
Tim
B
Bronco6684
Tim
I was thinking that but can you run a C4 with Explorer fuel injection, the concern is the kick down?
Probably not from the overdrive aspect, but certainly for the overall enjoyment aspect it still matters. The 3.50 and 33 inch tire combo is still not a happy combination for a C4.
But it’s been done…
Since it’s a frame up it sounds like you’re still into a pretty decent size budget, so perhaps changing gear ratios in the differentials for an extra thousand or three is not a huge uptick in the overall expense.
But I think if you’re going to the trouble of building a fun Bronco that you’re going to drive regularly you’d be better off making it more fun with better differential gearing.
I agree the C4 is the simpler install, and the bronco version being the better of them. It’s just that the C4 with it’s taller first gear does not necessarily accelerate quickly with the tall gearing and would also build heat like what is being mentioned earlier.
Otherwise it’s certainly a viable alternative with a change to the final drive ratio.
B
Bronco6684
The only thing locked in so far is that I bought the 5.0 explorer motor, yes the vehicle is completely dismantled now and well worth the investment of switching the gears, honestly I was trying to avoid that but to get the quality I want I suppose I need to start shopping for gear sets, so then the next question do I go with four tens 456s the largest tire I would consider running is a 33, I do have the ax15 or the C4 transmission if I do the 456 gears the ax15 though it brings up other cost would probably be my first choice, decades ago I built a Bronco with a healthy 302 C4 automatic and 350 gears on 33 in tires and I thought it did quite well, but maybe my standards weren't high enough
That’s possible, but I was going to recommend sticking with the gears you have until after the motor is done and you’re driving it.
The only person you need to please as far as performance goes you, and depending on how the engine actually runs, can certainly dictate which direction you go on the gear ratio.
So I wouldn’t change it at all until you’ve driven it with the new engine. That kills two birds with one stone so to speak.
It gives you the chance to decide what you need with more accuracy, but also saves you a chunk of change if it turns out that you’re happy with the performance.
Either way is a win.
As other stated time and time again, the 3.50 gears were highway gearing with the stock 27" tires. Without overdrive, 4.11s are well known to be a good overall gear on 33s. With overdrive something more like a 4.88 is what a Bronco runs around happily.
As for a kickdown, there are so many ways of doing that. You are not locked into the factory rod. As pointed out, cable versions do work. I got all fancy on my F250 where the rod was not going to be happy with the high rise intake and Holley Sniper. Since I already had an air horn, and an air tank, the WOT A/C cut off was repurposed into firing an air solenoid that cycled a little Parker air cylinder that was mounted down on the transmission. Very positive kickdown, with the rod I sometimes had a wonky kickdown where it was almost kicked down and almost not at the same time, almost a slipping as it was trying to go in and out of kickdown. Not good on a transmission.
B
Bronco6684
A lot of good advice out there and a lot of good options, currently I have the C4 but it would have to be rebuilt the ax15 but I would need the adapters, I picked up the explorer motor today so that part is a done deal leaning towards the AX15, current tires which are like new are only 30 by 9 and 1/2 I believe so I could put the vehicle together drive it like that and see where I'm at, ultimately there will probably be a second Bronco built with the spare parts.
