Just wanted to resurrect an older thread because Mark mentioned not having the tach hooked up was a problem. Is that something that the ECU needs? I thought it had it's own rpm sensor(s) and the dash mounted tach was strictly for driver information.
This not the case?
Also, while looking at RJM's two IAC units, it appears in the picture that even the angled plug version is facing the right way for our setups. Unlike the one we're working with now that is like in Mark's earlier pics.
The RJM harness' IAC plug won't reach it unless we rotate the valve 180 and rotate the connector 180.
Anybody done this to an IAC to make it work? Just wondering if it would mess anything up.
On a side note, I ordered an IAC for a '95 Mustang V6 and got one that came with a harness extension about 6 inches long. Just enough to make the RJM harness work as-is.
It turned out to be the incorrect part for the V6, but would be interesting to find that extension again.
Thanks.
