BroncoinAlaska
Been driving the bronco longer and longer distances breaking in the EFI so I can use it as my daily driver. It is running better than ever. It has good fuel pressure 40psi, and I have been chasing down all the smaller noises and potential problems. Untill it left me walking 3 miles from home today.
I took the bronco on a longer trip as I am trusting it more, 40 miles round trip for lunch. I put ten gallons in befor the trip. It worked flawlessly to lunch and almost all the way home. Then five miles from home it started missing then sputtering. Then at a stop sign it just died. It would crank, fire then die. I checked the gas cap and filter that I have on the BCB tank vent it was half full of fuel. I could hear the pump prime each time. Checked spark, OK. I was pretty sure it was no fuel situation. I cranked it one two manny times and started to get the solenoid click.
So I towed it home and I am charging the battery. I am thinking it is the pump in the BC Broncos tank. Any other ideas?
SPECS:
Ford 5.0 GT40X crate motor
BC Broncos 23 gallon tank
BC Broncos hard fuel lines and braided lines with fuel pressure guage
24lb ford racing injectors
Matched MAF
Aeromotive adjustable fuel pressure regulator
SPECS:
Matched MAF
